Sponsored by: CARiD
is it the same as a Toyota
Old Jun 17, 2009 | 03:55 PM
firsttruck1985's Avatar
is a Dana 44 the same as a 1985 Toyota axle
Old Jun 17, 2009 | 03:58 PM
881stGenRunner's Avatar
VERY DIFFERENT!!! not near the same
Dana -
Toyota -
Old Jun 17, 2009 | 04:01 PM
and a Hybrid Toyota axle???? is it the same as a 1985 Toyota axle
Old Jun 17, 2009 | 04:08 PM
a hybrid between a dana and a toyota??
http://www.off-road.com/toyota/trail...p2000/4025.jpg
naw they are different too. and stock 1979 - 1985 solid front axle are the same
Old Jun 17, 2009 | 04:55 PM
4runner Freak's Avatar
No they're not.
'79-'82 have no gusset
'83 has a short gusset
'84-'85 has a long gusset
Old Jun 18, 2009 | 10:48 AM
so a 82 can fit like a 85 axle ???
Old Jun 18, 2009 | 10:52 AM
4Crawler's Avatar
Yes, the factory front axles are all the same physical dimensions so can interchange without problems. As noted above, the only significant difference is the gusseting under the driver's side of the axle housing.
Old Jun 18, 2009 | 10:56 AM
so i can buy the 82 axle to make SAS on my 89 4Runner ?????
Old Jun 18, 2009 | 10:57 AM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
omg dude you really need to start searching (or search harder) and stop with the threads.
Old Jun 18, 2009 | 10:59 AM
4Crawler's Avatar
Yes as I mentioned above, the physical dimensions (spring perch width, steering, brake mounts, 3rd member, axles, etc.) are all the same. You may want to get an after market axle gusset kit to brace up the driver's side. They weld on top of the housing.
Old Jun 18, 2009 | 11:00 AM
no good threads !!!!!!!!!!!
Old Jun 18, 2009 | 11:03 AM
4banginRunner's Avatar
X2!
Old Jun 18, 2009 | 11:04 AM
scuba's Avatar
Yeah, Because your hogging up the bandwith with one like this.
This is simple stuff to an extent, and has been covered tons of times on this site and hundreds more.
Take your time and do some reading before you post some silly question like this..
Im going to start reporting noobs for useless posts and post padding, This place is getting rediculous.
Thank you
eighty5yota's Avatar
Old Jun 18, 2009 | 11:09 AM
toylocost's Avatar
Dont just search yotatech. Search google.
You know what? You should just start reading this...
Old Jun 18, 2009 | 11:32 AM
ozziesironmanoffroad's Avatar
Thank you
id rather answer questions over and over than the top gear video be posted everyday.
i cant figure out how to post the video, so im going to quit trying.
Old Jun 18, 2009 | 11:39 AM
toylocost's Avatar
Here you go...
[YOUTUBE]Lrk6vsb77xk[/YOUTUBE]
Old Jun 18, 2009 | 04:36 PM
Here you go...
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
