Sponsored by: CARiD
Want to Pull Out Engine ONLY...!!!
Old Jun 11, 2009 | 02:52 PM
Rexd699's Avatar
Howdy,
I just picked up a 98 4Runner with 3.4 and Auto Tranny.
I need to pull the motor, I want to pull ONLY the motor...!!!
Dose anyone have a trick to gain access and puling out the bolts holding the Engine Flywheel and Auto Flexplate together.
I was under there last night and spent 2.5 hours just getting the Cover plate off. Next is getting to the six bolts holding everything together.
I really do not want to pull both the engine and tranny out together.
Any help would be greatly appreciated~~~>>>BIG TIME
Thanks,
Rex M.
Old Jun 12, 2009 | 10:45 PM
85TurboRunner's Avatar
You'll probably have to go through the hole for the starter unless there is an access hole somewhere else.
Old Jun 15, 2009 | 11:29 AM
Rexd699's Avatar
Hot DAMN...!!!
I bet you are RIGHT ON...by going through the Starter Hole...!!!
THANKS~~~>>>BIG TIME...!!!
I'll be trying it when I get home tonight.
Thanks Again,
Rex M.
Old Jun 15, 2009 | 12:16 PM
24Runna's Avatar
When I did my engine swap I Got the access cover off at the bottom of the bell housing and then you see one screw and undo them one at a time.
bigjstang
Jun 2, 2025 03:56 PM
crashburnoveride
Aug 28, 2015 09:20 PM
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
