Sponsored by: CARiD
22r Timing problem
Old May 16, 2009 | 09:47 PM
slow_yota's Avatar
22r Timing problem
my distributor is set all the way retarded but my timing is way advanced. what could be the cause of this problem?
Old May 17, 2009 | 09:04 AM
DeathCougar's Avatar
Tooth off on the timing chain, or you put your distributor in a tooth off. Pretty easy fix if its just the dizzy.
Old May 17, 2009 | 09:40 AM
raydouble's Avatar
Pull valve cover
Roll up to TDC and make sure the cam and crank marks are lined up
Pull distributor and reset per FSM
Download here
http://www.ncttora.com/fsm/1985/1985FSM.pdf
Old May 17, 2009 | 09:43 AM
Plumbrbob's Avatar
find TDC and restab that dizzy
Old May 21, 2009 | 02:54 PM
slow_yota's Avatar
everything is set right. but timing is still off and theres a lag at around 4000 in second gear and on to third gear. if i put the distributer a teeth off the timing comes better but theres a really bad lag.
Old May 21, 2009 | 11:05 PM
raydouble's Avatar
Is it possible cam timing is off?
Old Jun 4, 2009 | 01:07 AM
slow_yota's Avatar
ok.i tried adjusting the distributor.i moved it a tooth over, the farthest advanced i can go is 0.
GreenLion
Jun 7, 2021 10:49 AM
Jmiller1023
23
Aug 6, 2015 07:03 PM
bigblue82
10
Jul 6, 2015 08:27 AM
thelifeadventure
Jul 2, 2015 03:09 PM
83flatt
Jul 2, 2015 10:30 AM
