22r Timing problem
my distributor is set all the way retarded but my timing is way advanced. what could be the cause of this problem?
Tooth off on the timing chain, or you put your distributor in a tooth off. Pretty easy fix if its just the dizzy.
Pull valve cover
Roll up to TDC and make sure the cam and crank marks are lined up Pull distributor and reset per FSM Download here http://www.ncttora.com/fsm/1985/1985FSM.pdf |
find TDC and restab that dizzy
everything is set right. but timing is still off and theres a lag at around 4000 in second gear and on to third gear. if i put the distributer a teeth off the timing comes better but theres a really bad lag.
Is it possible cam timing is off?
ok.i tried adjusting the distributor.i moved it a tooth over, the farthest advanced i can go is 0.
