Sponsored by: CARiD
87 runner in need of help
Old May 24, 2009 | 07:27 PM
bluegoose95401's Avatar
hey guys im just gonna sey im a old ford guy i know nothing about efi or electronic stuff but heres my prob i got a 87 4runner 22re 5spd when its at an idle it sounds like its missing a beat. goin up a hill or at 3500 rpm when im drivin on the flat roads it studders and jerks around and wont pass 4000rpm changed fuel filter plugs air filter cleand distributer cap and rotor im havin the O2 sensor checked on monday any tips would greatly be appretiatied
bluegoose
Old May 24, 2009 | 07:50 PM
Kiroshu's Avatar
Timing? Vaccum leaks? Hows cyl(s) compression? Distributor cap and button? EGR?
Old May 24, 2009 | 10:39 PM
cyl compression is 150 at cyl number 1 cyl 2,3,4 is 120. there were no cracks in the distributor cap so i scraped all the contacts off the cap and rotor with a knife took all corrosion off
Old May 24, 2009 | 11:12 PM
wyoming9's Avatar
Talking
Did you just get this vehicle??
You don`t say anything about changing the spark plug wires which could cause the issues described. Also look at all the vacuum hoses they can be on wrong or old and brittle.
Old May 25, 2009 | 07:57 AM
Kiroshu's Avatar
Air filter dirty? Vacuum Leaks? Breaks in plug wires? Coil? Any check engine light?
Old May 25, 2009 | 07:46 PM
no check engin light. i put a new air filter in last week no change the plug wires look new they dont look like they have any cracks or breaks hoses look stiff but not cracked im thinkin bout spryin starter fluid on the hoses to see if there are any leeks dose that work on efi my friend had unplugged the egr valve and plugged it off cuz he says it makes a diff in proformance i pluggd it back in no it starts at a lower rpm now
Old May 25, 2009 | 07:50 PM
ive had this truck for alittle over a year it never had any probs untill now
Old May 26, 2009 | 11:01 AM
Kiroshu's Avatar
Well unless the egr is stuck open or closed it should not be causing any issues..... try changing the coil you would be surpised that a coil and cause a cyl miss fire. All EGR is for is emissons it has no real performance enhancing feature. You can block it off and it not hurt a thing but if its stuck closed or open it may hurt engine performance. You can try tapping the egr valve with a hammer wit the engine running and see if it stops. I don't think its mass airflow related but try beating on the mass air flow sensor and see if there change. O2 may help but i doubt it. Intake manifold gasket leak?
Old May 27, 2009 | 08:44 AM
i had the egr blocked off because my buddie said it helped with the prformace of the motor. i hooked it back up same thing just a litte sooner and the motor has to be warmer now do you think it could be the hose form the air filter to the intake if that has any cracks it it the mass airflow woulnd not sense the extra air and at a higer rpm woulnt it suck more air in? just a thought what you think
Old May 27, 2009 | 08:47 AM
the intake gaskits look new still
Old May 27, 2009 | 09:33 AM
ozziesironmanoffroad's Avatar
what i want to know is why one cylinder is way higher than the other 3.....
Old May 27, 2009 | 02:56 PM
so i tapped up the air intake tube tappd on the mass air sensor and egr valve with the back side off a wratchet then drove it it for the10 mins it ran worse that it has been no power sluggish idle hard to take off the after 10 mins i hit the gas and it sluggish ly ehnt up to 3400rpm then whent pop and it was all better so im thinkin ya its fixed so i drove it for another 2 hrs and slowly it started comin back so now im back to square 1
Old May 27, 2009 | 03:01 PM
also when i took the air tube off there was some sorta sludge inside the intake manifold not sure whar it was or if thats normal kinda like a blackish color no real distinguishable smell
Old May 29, 2009 | 01:53 PM
wyoming9's Avatar
Talking
That happens you need to get some good throttle body cleaner.
You don`t want any leaks in the air intake hose that will mess things up.
If you have not changed the spark plug wires it might not be a bad idea .
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
