Sponsored by: CARiD
94 Runner 3.0 Engine Noise ?
Old Nov 18, 2009 | 05:55 AM
RCGRT's Avatar
Hello to all. I recently purchased a 94 Runner 3.0 with an obvious "klattering" noise. It turned out to be a completely wiped out rod bearing. So I pulled the engine, and went back in with a new crank and bearings. (mains and rods). New seals and timing belt. Everything else seemed ok, so nothing else was replaced. At initial start up, and since then (it has about 200 miles on it now) it's making a slight "ticking/tapping" noise. It's definately not a deep klatter like before. I can hear it from inside while driving with everything off and the windows up. If the windows are down, I can't hear it, (just for an idea of how loud it is). It does seem to run with the RPM. It seems just a bit quieter when its cold. I'm looking for any suggestions as to what it may be. Could it be valve train noise? Fuel Injectors? It has 163K miles on it, and supposedly the Engine was replaced with a remanufactured one about 80K miles ago. Everything else seems to be fine, performance is ok, no missing or other obvious problems or noises. I would be glad to post pictures or video if needed. Any help would be greatly appreciated. Thanks in advance
Old Dec 28, 2009 | 12:22 PM
colsoncj's Avatar
Could just be injectors, but they should be a little quieter than that. You might check the EGR system. IIRC theres a valve somewhere on the pass side that went out on a friends 94 3.0 which then cause a sound like an exhaust leak = ticking.
Personally, i'd just keep an eye on it and see if it gets worse, or if you could pinpoint the location of where its coming from.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
ZONAYODA
Jun 30, 2015 05:36 PM
nyk08trx
Jun 18, 2015 09:01 PM
yamaha73
Jun 18, 2015 06:19 PM
HALMAN
Jun 14, 2002 09:02 PM
