Sponsored by: CARiD
Newbie 22RE questions
Old Oct 26, 2009 | 04:49 PM
destin4dirt's Avatar
ok so i have a 1990 4x4 with a 22re and i know it has the in tank fuel pump.so what will i need to put a fuel cell on it?
Old Oct 28, 2009 | 11:35 PM
ajoebob's Avatar
if you wount to use a fuel cell you will have to use an exturnal fuel pump
Old Apr 14, 2010 | 03:36 PM
from 22re to 22r Conversion need help
hey i have a 1990 4x4 and im trying to find out what i need to go from 22re to 22r. im lookng to get the webber kit of ebay.but i need some help on what all i need to do this? do ineed a new throttle cable? and i think i will also need a new fuel pump.any1 that has done ths befor plz help!
Old Apr 15, 2010 | 12:14 PM
thebrick's Avatar
Why would you want to do this? that is a major downgrade. You would end up losing power and drivebility, defintely a bad idea.
You would need a new intake manifold (post 85), fuel system, a carb, intake, custom wiring harness, vacuum tubing, ditch the computer, throttle cable, plus a million little odds and ends. oh, and crazy pills...
Old Apr 15, 2010 | 12:30 PM
toyota4x4907's Avatar
There was a thread about this just a few weeks ago. Search
Old Apr 15, 2010 | 01:39 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
OMG... not another one...
well... that's gonna be one messed up 90...
Right off the top of my head, I'd say you need a carb fuel tank... And get ready for a check engine light to be staring you in the face, b/c I don't have a clue what would keep that from going off...
Just cut the power wire to it. Everything else is gonna be rigged, why not that?
Old Apr 15, 2010 | 07:21 PM
1990 efi help plz!!!
i dont know jack about efi and i need help.ok so im making a truggy from my 1990 4x4 22re and i need to find out if there is a bare bones wireing harness just to make the motor run. The wriring at the moment is a total mess and like i was saying it just needs to make the truck run. it does not need to be street legal or run gages or anything like that. This thing is only going to be going in the sand, and is basicly going to be a sand rail. so if anyone can help me simplify the wiring it would be awsome, or if there are any harnesses like that on the market.And also if anyone has a list of all the sensors involved with the efi that would help alot because im trying to avoid to just switching to a carb and as i said before i dont know jack about efi. Also are there any sensors I can just cut out to make it more simple?
Old Apr 15, 2010 | 09:56 PM
truggy efi help plz!
Old Apr 15, 2010 | 11:45 PM
limon32's Avatar
Simple answer is no, if you want simple you have to go back to the carb. Otherwise download the FSM and learn to read wiring diagrams and use a DMM because thats the only way EFI will work is with all the sensors.
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
RaginAsian91
All Other Toyota Swaps
Aug 23, 2015 10:27 AM
garagespace
Jul 9, 2015 08:37 AM
