Sponsored by: CARiD
Rear brake problem.
Old Aug 3, 2010 | 09:39 AM
95blackToy's Avatar
Exclamation Rear brake problem.
On my 95 extra cab i decided to remove my wheel and check out my brake drums. Well the passenger drum was covered with greasy gunk, and when i got it off the inside had wads of nasty black grease. It was all over the shoes the drum, and all the components. What could cause this. My Brake fluid is full and i have never had to add any to it.
Old Aug 3, 2010 | 09:43 AM
PismoJoe's Avatar
Sounds like the rear axle seal is leaking on the passenger side
Old Aug 3, 2010 | 09:46 AM
95blackToy's Avatar
Thanks man. The axle has to be removed to put that in, correct?
Old Aug 3, 2010 | 09:48 AM
PismoJoe's Avatar
No problem
Yeah its not too bad though, heres a good read to get you thinking of what needs to be done http://www.4x4wire.com/toyota/mainte...axle/oil_seal/
Old Aug 3, 2010 | 09:58 AM
95blackToy's Avatar
thanks man il be getting on that here in the next day or two. good link by the way
Old Aug 3, 2010 | 10:00 AM
PismoJoe's Avatar
Good Luck! BTW you should do both of the axle seals at once while you're in there, and you might want to look into a diff breather mod so your seals have less of a chance of blowing out again
Old Aug 3, 2010 | 10:11 AM
95blackToy's Avatar
alright cool. I'll do both and diff breather mod is simple isn't it?
Old Aug 3, 2010 | 10:30 AM
PismoJoe's Avatar
Yup, very simple. The fitting that threads into the diff is the smallest fitting on the 22RE intake plenum, easy grab at a junkyard. Even if you order it from toyota, its no more than $5.
Here's a good thread on it: https://www.yotatech.com/forums/f129...her-mod-75747/
Old Aug 3, 2010 | 11:08 AM
95blackToy's Avatar
thanks again man. Big help
Old Aug 3, 2010 | 11:09 AM
PismoJoe's Avatar
No worries
Old Aug 3, 2010 | 01:51 PM
BeenYota's Avatar
2nd the diff breather. My rear diff started leaking after a long road trip. Popped her open and the fluid ran out all watered down. After re-sealing and filling, i'm going to install a breather extension. Anyone else have good links or pics I can reference?
Thanks,
Old Aug 6, 2010 | 02:05 PM
bmxjedi's Avatar
same thing happened to my truck Black Toy... It was very simple, i just followed the steps from the same link above! X3 on the diff breather, my truck sees alot of water and mud, so it was a must!
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
Jnkml
Jul 6, 2015 01:20 PM
