Sponsored by: CARiD
lift kit for 81??
Old Jan 13, 2010 | 05:07 PM
shmitty's Avatar
lift kit for 81??
I am looking to put about a three inch lift on my old pickup and didnt know what kind is the best bang for the buck im a big fan of toy tech lifts but was just curious about some other brands any suggestions?
Old Jan 14, 2010 | 04:32 PM
oldschool4runner's Avatar
Do you want to go cheap? Or do you want quality? I installed Skyjacker. It has a better ride that I had stock. Some say that they don't flex as well, but it works for me. The cheapest lifts are Rough County. But there are lifts that can cost over a grand. Are you going to install it yourself? I've installed a couple of 3" lifts with a bottle jack. Good luck!
Old Jan 14, 2010 | 04:42 PM
runnerboyy's Avatar
Custom rears up front pack and chevies out back.
Old Jan 14, 2010 | 05:08 PM
SpecialScottie's Avatar
x2
Old Jan 14, 2010 | 05:15 PM
Van Cour's Avatar
just put leaf spring in it super cheap super great ride and made flex.. and yes its what the old trucks only need no need for fancy stuff it would be there for no reason.. these trucks on need leafs and shocks. get some jeep wagoneer springs......
Old Jan 14, 2010 | 05:28 PM
peow130's Avatar
Uhhh...
Cheapest way to get 3 inches of lift or more:
Rears up front
63" chevies out back.
You'll find the chevies for around 50-100 bucks
New hangers, probably like 50..
Old Jan 14, 2010 | 06:01 PM
yota8083's Avatar
I 4th the Chevy's and RUF's. I just put mine on and love them. Ride good, flex good, And Everything was free for me
Old Jan 16, 2010 | 07:36 PM
smallenginemechanic's Avatar
For factory spring pack and size, rough country? or tough country? 3-3.5" lift. My truck has add-a-leafs, installed wrong, rides like there is no suspension, I almost need a kidney belt... lol. Dual rancho shocks doesn't help either, there's no weight!!
Old Jan 16, 2010 | 08:13 PM
runnerboyy's Avatar
Why dont you install the add a leafs "right"??
Old Jan 16, 2010 | 11:23 PM
The wrong hardware to begin with, and why try to beef up worn springs?
Old Jan 16, 2010 | 11:47 PM
dropzone's Avatar
Fossilized
toytec does not list any thing for truck older than '86
best bang for buck as said "RUF": Read This
63" chevy out back: read this
You did not mention if you want to have stock length springs that will bolt into the stock locations...OME is good if that is what you want. Superlift has an OK reputation....
comes down to what you want to do with the truck, just lift for tire clearance or functioning suspension....just stay away from the back breaker cheap lift off of ebay
most of the good aftermarket springs are long and will require welding etc...
Old Jan 17, 2010 | 09:54 AM
runnerboyy's Avatar
Because it seems as if you do not want to go with the best option.... springs that are the stock length with that much added arch are going to usually ride like crap.
Old Jan 17, 2010 | 08:19 PM
I never thought of that, so should I get new chevy springs and new rear toy springs?
Old Jan 17, 2010 | 08:27 PM
runnerboyy's Avatar
no, used junkyard springs will work just fine, and im sure they are wayyyy cheaper. you should be able to get all 4 springs for 100 bucks.
Old Jan 20, 2010 | 10:39 AM
monstertruckman's Avatar
i am running 4 inch pro comp springs
Old Feb 4, 2010 | 04:34 PM
Fink's Avatar
Moved to Newbie Tech Section.
Old thread but belongs here regardless.
Fink
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
