33x10.5 4.10
33x10.5 4.10
So i am wanting to get some 33x10.5 BFG's on my 91 4runner with a 1" BL.
I have the stock 4.10 gears
I also have a 1" BL
How will my 4runner do with the 33x10.5's and the 4.10 gears
And do u think i will be able to fit them. I dont believe there will be any rubbing since there the 10.5's
Any help would be great
I also have a 1" BL
Probably will fit OK on stock wheels, might need to doa little fender trimming if needed:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
You'll probably find 5th gear is not usable, but with the taller tires, 4th gear will be about the same overall ratio. Likely will get more clutch wear. Keep an eye out for a set of used 4.56 or 4.88 diffs and swap them in when you get a chance.
FS[MidAtl]: fZJ80 9.5" rear axles w/ e-lockers complete
I8URSVT
Oct 5, 2015 07:23 PM
FS[PacSouthWest]: 8-Inch Axle, '97 4R, 4.10, Drum to Drum-Complete
SharpStick
Aug 29, 2015 12:59 PM
FS[NorAtl]: Elocker 3rd with motor complete
mtb_taco
Aug 20, 2015 12:16 PM
