Sponsored by: CARiD
Couple of quick questions
Old Jan 15, 2010 | 01:43 PM
Duckie's Avatar
I'm planning on doing some zuk style coils, weldless edition. But I have a few questions before I start. One is how do I safely jack the rear of the vehical up since it's already lifted? My floor jack can't reach the frame, so ibwas wondering what some other people are using.
My other question is that since my truck has the 4in lift, it has blocks in the rear. Obviously I want to remove those for the spring, but they put in longer ubolts. Where is the best place to get stock size u bolts to put back in?
Thanks guys
Old Jan 15, 2010 | 01:52 PM
4Crawler's Avatar
Floor jack under the axle, raise it up to clear some 6- or 12-ton jack stands under the frame. Then remove the wheels and lower the frame onto the stands. Use fllor jack under axle to raise/lower it as needed to install springs.
U-bolts, see if your have a long threaded section, if so, might be able to cut them shorter. Otherwise, try a local spring/suspension shop or a 4wd shop and they can get u-bolts made to order. And if you still have bolts pointed down, consider a u-bolt flip kit, costs about the same a u-bolts and gives more clearance and keeps the threads out of the rocks.
Old Jan 15, 2010 | 09:09 PM
one wheel's Avatar
Can anyone tell me what the largest size wheel/tires I can put on my stock, 93 pickup is. Mostly for looks.
Old Jan 16, 2010 | 01:16 AM
Duckie's Avatar
Seriously, in my thread? Do a search bra. Hell don't even search, just scroll down the list of recent threads and you will see more than one topic covering that.
jasonty
41
Dec 23, 2018 01:00 PM
DrZero
18
Jul 24, 2015 11:31 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
icentropy
Jul 14, 2015 10:23 AM
Jnkml
Jul 6, 2015 01:20 PM
