Sponsored by: CARiD
please help (twin sticks)
Old Jan 29, 2010 | 12:36 PM
myyota85's Avatar
i bought a set of twin sticks from trail gear and installed it. well when i put the tranny in 2nd gear it totally hits the new twin stick and pops it in neatural. then it hits 4th gear and theres know way i can even try to get in reverse. so i call up T. G. TECH and they say cut the tranny stick in half (this will solve my problem) well any guys installed the twin stick and what did u do? i dont own a welder and dont really want to cut my stick in half. i have a 85 pickup 3 inch body lift but i dont think thats my problem. please help i hate to buy something and it not work. ill put a pic up if needed.
Old Jan 29, 2010 | 12:42 PM
waskillywabbit's Avatar
Single or dual cases? Forward or top shift?
Body lift that tall ain't helping.
Old Jan 29, 2010 | 01:09 PM
myyota85's Avatar
forward shift case single is it the body lift? thanks wab fab
Old Jan 29, 2010 | 01:36 PM
Twin sticks on a forward shift case is tight and I think TG specifies different twin sticks for the different tcases, top vs forward. Body lift just exaggerates fitment due to minimal throw. Heat up shifter and bend or cut and reweld.
Old Jan 29, 2010 | 01:38 PM
4Crawler's Avatar
Body lift should not affect the shifters hitting each other (i.e. they would hit regardless of where the body is) unless of course the shifter was bent to install the body lift. You could try bending the transmission shifter to clear the t-case shifters or bend the t-case shifters to clear the gear shift.
Old Jan 29, 2010 | 02:05 PM
myyota85's Avatar
the tranny shifter?
Old Jan 29, 2010 | 05:29 PM
myyota85's Avatar
does any one have the trail gear twin sticks?
Old Jan 29, 2010 | 05:31 PM
4Crawler's Avatar
Originally Posted by myyota85
the tranny shifter?
Bend one or the other until the sticks clear. The base of the shift lever is a smaller diameter and easy to bend:
- http://www.4crawler.com/4x4/ForSale/...l#ManualTranny
Old Jan 29, 2010 | 05:42 PM
myyota85's Avatar
would u heat it or just brute force (bending)?
Old Jan 29, 2010 | 05:48 PM
4Crawler's Avatar
Cold works best, the lower part is set into plastic inside the upper part of the shifter.
TheBFA
Feb 15, 2020 06:55 AM
primordialbeast117
Dec 19, 2015 12:23 PM
JUICE222
Oct 13, 2015 08:50 AM
irv
Sep 29, 2015 01:04 PM
yoterr
Sep 15, 2015 06:26 AM
