Sponsored by: CARiD
O2 sensor problems
Old Feb 8, 2010 | 10:47 AM
Chuck Manners's Avatar
O2 sensor problems
i have a 1990 toyota pickup reg.cab 5 speed 22re motor my check engine light came on and it started to idlea very rough and sometimes stall out allong with poorgas milage 8 MPG. it turned out to be because of my O2 sensor i unpluged it and my truck ran like normal except for very poor gas milage 11 mpg. when i got the truck a few weeks ago it was getting around 17 or 18MPG.so i installed a new O2 sensor and when i pluged it back in it started right away with rough idle and really bad gas milage. any ideas of what it could be?
Old Feb 8, 2010 | 10:49 AM
CappyKD's Avatar
Did you reset the ECU when you installed the new O2 sensor?
Old Feb 8, 2010 | 11:08 AM
no i didnt. what do i have to do to reset set the ECU?
Old Feb 8, 2010 | 11:25 AM
CappyKD's Avatar
Pull the EFI fuse under hood and also pull the negative battery cable at the same time.
Old Feb 8, 2010 | 11:31 AM
ok thanks i will give that a try.
Old Feb 8, 2010 | 11:36 AM
CappyKD's Avatar
once you do, start it and let it idle for 10-15 minutes.
Old Feb 18, 2010 | 09:28 AM
chuck
hey thanks a bunch CappyKD resetting the computer after plugging in the new O2 sensor fixed the problem. getting normal gas milage now
sandyota
Feb 4, 2021 11:16 AM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
