Sponsored by: CARiD
Steering Wheel Vibration 2001 4-Runner
Old Apr 23, 2007 | 05:09 PM
jeh250's Avatar
I've got a slight but irritating steering wheel vibration in my 2001 4-Runner that has been difficult to cure. Bought the vehicle new and had dealer service for the first 30k. Through a cross country trip and 30 min. highway ride to the dealer for 30k service, no problem. The service, scheduled for 1/2 hour, mysteriously took over three hours. Returning from the service, noticed slight vibration. Returned to dealer who diagnosed as bad Bridgestone tire (not under warrantee). Sensing BS, I had independent mechanic install new Cooper tires, including spin balance. No great improvement, no suggested solution.
Whatever happened, occurred at the 30k dealer service. Looking at the repair slip I noted that it includes "lube axle shafts" which is a first time procedure for this vehicle.
Could they have damaged these axle's or reinstalled them incorrectly? I'm out of ideas and sure would like to fix this fine SUV which has otherwise been perfect.
Old Apr 23, 2007 | 09:25 PM
Texas_Ace's Avatar
My first impression was warped brake rotors. This is a well know issue with stock 4runner brakes.
but with it happning at the dealer i really don't know what the problem is.
Old Apr 25, 2007 | 07:16 PM
Shoua's Avatar
At what speeds do the vibrations show up? It COULD possibly be a bent rim, in which case the dealership couldn't have done unless they test drove your vehicle for some strange reason. It could be warped brake rotors IF the symptoms only show up while braking.
Old May 1, 2007 | 08:40 PM
jayclev's Avatar
is this normal
I have the same issue, but it only occurs at highway speeds. This could be due to the oversized tires. It's not a major vibration, just slightly annoying. I haven't driven any other 4runners, so I'm not sure if it's normal.
mussy01
Dec 13, 2016 08:20 PM
Up&Down
Aug 11, 2015 10:04 AM
RBK
Aug 1, 2015 01:55 PM
terminator
Jul 27, 2015 07:13 PM
