Sponsored by: CARiD
Air conditioning smells like an old sock
Old Jul 8, 2007 | 08:58 PM
dglane's Avatar
Does anyone know the true tricks on how to get rid of the smell from the air conditioning in a 2000 4Runner?
Just bought the truck two days ago, very happy with it, but it is forcasted to be 108 this wednesday.
Thank you for any information,
DGLane
Old Jul 8, 2007 | 09:01 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i dont know how to get rid of it but youre not alone. ive smelled that in all 3 toyotas ive owned
Old Jul 8, 2007 | 09:13 PM
stormin94's Avatar
The cabin air filter probably is real dirty, and smells like it too. My 4Runner's air quit stinking after a while...but you may want to change that.
Old Jul 8, 2007 | 10:17 PM
colsoncj's Avatar
In my mothers 94, condensation would build up somewhere, but I dont remember where... another thing, her drain boot at the evaporator shroud in front of the firewall would clog up, also causing smells... dont know if the 3rds are similar in design, but its another thing to check.
Old Jul 8, 2007 | 10:31 PM
91muddog's Avatar
make sure your oil isnt leaking onto the exhaust.
that was my problem
Old Jul 9, 2007 | 07:56 AM
frodin1's Avatar
I saw a post on here a long time ago that said to spray Lysol directly at the base of the widshield "on the inside" with the air/ a/c on high. Apparently the intake for the A/C is there and it will draw the lysol into the system and kill the mold growing in it.
Old Jul 9, 2007 | 07:58 AM
frodin1's Avatar
I wasn't aware that 2000 runners had cabin air filters?
Old Jul 9, 2007 | 08:01 AM
4Crawler's Avatar
Here are some tips to find and fix the source of the odor (not a Toyota in the writeup, but the same ideas apply):
- http://www.4crawler.com/Diesel/Cheap...ml#ACDrainTube
Old Jul 12, 2007 | 06:37 AM
deserttoy84's Avatar
Just have to make sure your drain isnt clogged and if you want the smeel to go away. you go get a can of lysol spray, they make many different scents including a non scented one if you like any of the scents they offer. you spray a bunch in where you recirc is or turn on fresh air with the fan on high and spray a bunch through the vent between the hood and winshield. It will kill off any bacteria that might form from water sitting, so the air will be healthier to breath and it will also smell a whole lot better.
Eggslinger
Jun 8, 2019 03:32 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
Sidherish
Aug 2, 2015 01:42 PM
terminator
Jul 27, 2015 07:13 PM
