Sponsored by: CARiD
2nd gen ifs diff install
Old Nov 30, 2008 | 03:20 PM
chopyota's Avatar
This weekend I dropped the front differential out of my 4runner, but noticed that the power was not hooked up to the old diff. When I installed the new one I could not find where to plug the new one in. I guess the old one had been disconnected for a while. Any pointers as to where I need to look?
Thanks in advance.
Old Nov 30, 2008 | 03:26 PM
DeathCougar's Avatar
I think i am confused....what is not hooked up, the ADD portion of the front diff? Do you have pics of anything?
Old Nov 30, 2008 | 04:59 PM
chopyota's Avatar
The gasket is really messy, I will be removing the diff and cleaning this up, but just wanted to test it out. I guess this would be for the ADD portion of the diff.
Old Nov 30, 2008 | 05:02 PM
Pic no worky. Host it on photobucket
Old Nov 30, 2008 | 05:05 PM
chopyota's Avatar
I hosted it from there, and put it between the [/IMG] brackets. We'll see if this works.
Old Nov 30, 2008 | 05:08 PM
lets try this one..
Old Nov 30, 2008 | 05:10 PM
There we go. You had some extra unnecessary coding in there.
Anyways, that loose wire is for the sensor. The actual ADD portion is vacuum controlled. There should be a wire hanging down by the drivers side, near the oil pressure sensor that it will plug in to.
Old Nov 30, 2008 | 05:13 PM
olharleyman's Avatar
There should be a opposite end of that plug coming down from the fender wall to plug that into so it lights up on your dash showing you your in 4wd iirc
Old Nov 30, 2008 | 05:14 PM
chopyota's Avatar
Thanks, I hit some stuff that tore the armor off of the front before I replaced the differential. I tried to connect it to that wire but couldnt get the connection fit. If I still can't get it would it be bad to just hardwire this?
Old Nov 30, 2008 | 05:18 PM
The only reason the connector might not fit is because you used a diff from a later model truck, which has different connectors for the short sub harness. you can likely get the correct subharness from the dealer, or just reuse your old one if you still have it.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
jerusry
Oct 19, 2015 05:28 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
