Sponsored by: CARiD
Engine noise
Old Jan 6, 2009 | 10:20 AM
vincepower's Avatar
Engine noise
I drive a 1994 toyota pickup. My engine has been making a weird clicking noise. It is not extremely loud, but is definitely noticeable. It seems to stop sometimes. Any ideas of what this can be??? I have 160,500 miles on the truck.
Old Jan 6, 2009 | 10:25 AM
22REw/HP's Avatar
rod, main, valve adjustment, rock stuck in the tire.J/K. light click or heavy, click or knock, upper or lower part of motor?
Old Jan 6, 2009 | 10:30 AM
vincepower's Avatar
Light click. From what i hear id say upper part of engine.
Old Jan 6, 2009 | 10:31 AM
DC.Woods's Avatar
What motor?
Stops when?
22re timing chain...noise quiets down after warm up?
It could be your mudflap with that little info!!
more details please!!
Old Jan 6, 2009 | 10:51 AM
vincepower's Avatar
Originally Posted by DC.Woods
What motor?
Stops when?
22re. Its hard to determine but i think it stops once i reach a constant speed, like on the freeway. When i accelerate and slow down, it makes the noise. Im not sure this is totally accurate. What kind of noise down a bad timing chain make??
Old Jan 6, 2009 | 11:56 AM
vincepower's Avatar
Just went out and started the engine. I made a video, the sound sux but u can kind of hear the clicking. http://www.youtube.com/watch?v=JRPYZB1l1J0
Anyway, it wasnt clicking until i gave it gas.
Old Jan 6, 2009 | 12:30 PM
toyota4x4907's Avatar
Just sounds like a normal 22re to me
If you don't know, 22res are infamous for valve ticking Adjust the valves yourself (its very simple and will take less than an hour your first time) or pay someone to do it, but it will probably be at least $100.Then, while you have the valve cover off adjusting the valves, take a look down the timing chain area and see if your chain guides are broken and/or missing.
Old Jan 6, 2009 | 12:40 PM
The more I listen to it, the more its starting to sound like it IS coming from the front of the engine--timing chain area. Either way, warm your truck up, and take the valve cover off. Adjust the valves while there, or at least check them with a feeler gauge. should be .008" intake, .012" exhaust. Search on here for proper precedure, or if you have like a Chiltons manual, refer to that . (better yet, if you have done it before) I don't know your mechanical ability, so sorry if I offend you.
Old Jan 6, 2009 | 02:19 PM
vincepower's Avatar
Thanks for the help. A buddy of mine mentioned it could be a valve. I haven't done much with cars, so im on here to learn. Ill definitely look into checking the valves and Im thinking about changing the timing chain because i dont know if it has ever been changed on this vehicle.
Old Jan 6, 2009 | 03:39 PM
t-chains should be replaced between 140K-160K miles I believe. If/when you do the t-chain, replace the water pump and get some metal timing chain guides if it doesn't already have them.
How many miles does it have?
Old Jan 6, 2009 | 04:29 PM
vincepower's Avatar
160,500
Old Jan 6, 2009 | 04:36 PM
I bet you the T-chain needs to be replaced. I'm assuming it hasn't been done on this vehicle? I'm sure the valves are noisy as well.
Old Jan 6, 2009 | 06:08 PM
Levij83's Avatar
I've been hearing that on my 94 for a while...the timing chain was wore slap out and was smacking in the engine. Sometimes it would smack slow then sometimes fast, but never all the time. After i replaced my timing chain everything was quiet. Hope you get it sorted out
Old Jan 11, 2009 | 08:28 AM
mike mike 70744's Avatar
i ahve the same prob with my 1992 i bought it and the person i got it from said t chain was slappin i talked to a couple local shop owners they said same thing and on way home started worse. could it be a guide broke and slinging around in cover
Old Jan 11, 2009 | 08:55 AM
dotcom's Avatar
question. had the short block replaced by toyota under warranty 6kmiles ago. would they do the timing chain at that time or would the new short block come with a new one? im wondering when i should start to worry about it. truck has 206k miles on it now.
Old Jan 11, 2009 | 12:06 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
New short block from Toyota would have a new TC. To be sure, look at your reciepts. They would have listed all replaced parts.
Old Jan 17, 2009 | 05:00 PM
jwhitaker74's Avatar
My 22 re sounds exactly the same. I just replaced the whole top end except the rocker assembly with all new components, also did rings and bearings in the bottom. New timing chain new head new vlvs new tapets for rockers and it still sounds like that. I order all new rails and rocker arms cause i heard that if the old ones are worn il never get the clearances right. Should get the new rails and arms soon hope that works.if that quiets mine down after setting the vlv clearances ill let you know.
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Gamble_STi
Jul 7, 2015 07:54 PM
