Sponsored by: CARiD
WTF? is that noise
Old Dec 16, 2008 | 09:54 PM
MATTSRED's Avatar
WTF? is that noise
i took apart my dash to get to the lights behind the gauges.
taking it apart and putting it back together was easy but think i realized i put
something in wrong because it didnt turn the gauge lights on right away and now sounds like this ...
http://s71.photobucket.com/albums/i1...6082204-00.flv
if this video doesn't work its making a clacking sound and goes faster with the acceleration would something i plugged in wrong or bulb put in wrong make it start the clacking sound IDK...
Old Dec 16, 2008 | 09:59 PM
scuba's Avatar
why on coreys amazing YT would you make 2 threads?
Old Dec 16, 2008 | 10:17 PM
MATTSRED's Avatar
lol idk cuz im weird.
Old Dec 16, 2008 | 10:26 PM
scuba's Avatar
Or just disrespectful of the rules...
Again, Check your speedo cable that its plugged in all the way, or you may just need a new one...
Old Dec 17, 2008 | 03:36 PM
Jay351's Avatar
Speedo cable.. Make sure its plugged in all the way, shoot some grease into it. If it goes away (temp fix) then buy a new cable.
Old Dec 17, 2008 | 05:05 PM
grant526's Avatar
I had to get a new cable for my 85. The heat of the Exhaust Manifold cooked the housing around it, allowing it to contact the wires within the housing material and making a really nasty Grinding/rubbing sound. But is sounds like you just didn't get the speedo cable plugged back in all the way.
A way to test that without taking the entire dash apart again would be: Disconnect the speedo cable from the tranny and drive it. If the noise goes away, then you've probably found the issue. : )
Good Luck!
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
