WTF? is that noise
WTF? is that noise
i took apart my dash to get to the lights behind the gauges.
taking it apart and putting it back together was easy but think i realized i put
something in wrong because it didnt turn the gauge lights on right away and now sounds like this ...
http://s71.photobucket.com/albums/i1...6082204-00.flv
if this video doesn't work its making a clacking sound and goes faster with the acceleration would something i plugged in wrong or bulb put in wrong make it start the clacking sound IDK...
I had to get a new cable for my 85. The heat of the Exhaust Manifold cooked the housing around it, allowing it to contact the wires within the housing material and making a really nasty Grinding/rubbing sound. But is sounds like you just didn't get the speedo cable plugged back in all the way.
A way to test that without taking the entire dash apart again would be: Disconnect the speedo cable from the tranny and drive it. If the noise goes away, then you've probably found the issue. : )
Good Luck!
Good Luck!
zytra
Jan 24, 2019 03:16 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
