Sponsored by: CARiD
1991 4runner hub not locking
Old Dec 28, 2008 | 10:01 AM
dj choxie's Avatar
Axle spins for the 4wd but it does not lock to the hubs??? it worked great before it sat for a couple months??? Well when I put it into 4hi nothing happens no light or anything, don't even hear noise, but wen I put it in 4lo, the same thing happens except it goes slower cus its in 4lo, but my neighbor is a mechanic and he gave it a quick check before he left for vacation and he said the axle for the 4wd is not locking to the hubs, so he thinks it might be on of the hubs, but i need to fix it because there is a lot of snow here where i live about 2 feet, and he is not coming back till like saturday so i need help?? And there automatic hubs and its a 5speed 4runner v6.
Old Dec 28, 2008 | 05:07 PM
bigarms23's Avatar
are they auto or manuel hubs on could be broken
Old Dec 28, 2008 | 06:24 PM
waskillywabbit's Avatar
A LITTLE more information is needed. Please elaborate with some details.
Welcome to Yotatech.
Old Dec 28, 2008 | 09:24 PM
DeathCougar's Avatar
If its a stock 4Runner setup, it will be ADD.
And going on that assumption, its not the hubs that are causing the problem. With ADD, the hubs are always locked, via lock plates. There is no way from the front axles to NOT be spinning, unless you shatter/break something wheeling. Just sitting for a while won't cause said breakage.
Likely, your ADD actuator is not working, or is corroded.
Old Dec 30, 2008 | 06:41 PM
dj choxie's Avatar
So it's probably the ADD actuator not either hubs??? and do u know how much the would cost??
Old Dec 30, 2008 | 06:42 PM
dj choxie's Avatar
there auto hubs
dj choxie's Avatar
there i put more info on it
Old Dec 30, 2008 | 06:43 PM
dj choxie's Avatar
Old Dec 30, 2008 | 06:52 PM
4Crawler's Avatar
For ADD you have drive flanges not locking hubs. Basically drive flanges are like hubs that are permanently locked. ADD problems are usually related to mis-plumbed vacuum lines:
- http://www.off-road.com/toyota/tech/add
Old Dec 30, 2008 | 08:01 PM
dj choxie's Avatar
so u think its the vac lines???
Old Dec 30, 2008 | 08:05 PM
4Crawler's Avatar
Well check it out and see, there are full troubleshooting steps on the web page above. Most common issue I have seen is vacuum lines that are either not connected or swapped (so that the ADD actuator unlocks in 4WD).
Old Dec 31, 2008 | 09:59 AM
dj choxie's Avatar
well i check the vacumm lines under the hood and they look correct too me but i couldnt locate the ones by the wheel..
Old Dec 31, 2008 | 11:19 AM
There are no vacuum lines by the wheel. The only vacuum lines run down to the ADD actuator in the front diff.
4Crawler already pointed out that you have drive flanges, so its not possible to ever unlock the CV axle from the hub/spindle.
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
AaronM
Jul 8, 2015 07:15 PM
ItsJustD
Jul 7, 2015 07:49 AM
zd92655
Jul 5, 2015 04:25 PM
