Sponsored by: CARiD
Should I Still Try and Drive this Thing?
Old Aug 14, 2017 | 05:29 PM
Ididsomethingstupid's Avatar
Rather ashamed of this. I recently acquired a '93 yota pickup, 4wd automatic. Went to change the oil for the first time, and instead dumped all the tranny fluid, added 5 quarts of oil to the motor (in addition to the 5 quarts that were never drained) and drove it not too far before the smoke was billowing from the exhaust and the tranny was acting funny. I've refilled the tranny fluid, drained all motor oil and refilled to correct level but haven't even started the thing yet. Does anyone have any suggestions as to the most likely fix this is going to require and if I should be driving it? Thinking blew a valve seal but I don't know much.
Old Aug 14, 2017 | 05:38 PM
dropzone's Avatar
Fossilized
won't know till you fire it up
Old Aug 14, 2017 | 07:16 PM
cr@ves4wheelin's Avatar
The damage (if any) is already done. So what ^ he said. Just shift through all your PARK REVERSE DRIVE ETC with the brakes on and hold each for like 10-20 seconds before driving it out on the road.
Old Aug 15, 2017 | 06:31 AM
I did as you said with shifting through everything and drove it around the block. Transmission is behaving as is should but im still dumping white smoke out of the exhaust.
Old Aug 15, 2017 | 06:44 AM
How long did you run the truck with the excess oil? Just curious.
The smoke, most likely, is any oil that is getting burnt in the cylinder. My guess is that when the crankshaft aerated the oil in your block, some may have gotten into the cylinder somehow. If it does stop after a while, I would run some seafoam or something to clean up your cylinder and intake with, as well as a fuel additive for the injector. Keep an eye on oil pressure and coolant temp just in case.
Old Aug 15, 2017 | 07:10 AM
I drove it about a half mile to a tire place and had new tires put on. I picked it up later and was driving it straight home when it started dumping smoke. Thinking maybe a valve seal blew? After driving around the block this morning the coolant seemed hotter than I'd expect.
Old Aug 15, 2017 | 07:12 AM
arlindsay1992's Avatar
The smoke from the exhaust will most likely dissipate. Being so overfilled, the engine oil probably got foamed up and went who knows were. Probably puked through the PCV system and into the intake. It'll all burn itself away eventually after a few miles. I doubt you did any damage to the engine. As for the transmission, running it dry isn't good for it but if you stopped as soon as you noticed then I doubt it's fatal. Certainly wasn't good for it but I don't think you killed it.
Old Aug 15, 2017 | 07:17 AM
I don't think you could have possibly blown a valve seal. They have such a small effective area that it would take a huge amount of pressure to disturb them. The main seals have a much larger effective area and would be more prone to blowing. Although I'd say the likeliness of that is pretty low too.
Old Aug 15, 2017 | 07:20 AM
That's good to hear.The exhaust smoke does seem to have slightly gone down but is still at an alarming amount. I suppose I'll take it further and see what happens.
Old Aug 15, 2017 | 10:14 AM
skypilot's Avatar
White smoke is water. Blue is oil, and gasoline is black.
Check your coolant levels, may have been something wrong there before you started. I doubt you did more than an oopsie.
Over filling oil just foams it up,all I can think of is oil locking a cylinder and popping a head gasket letting water into that hole. Just check all your fluid levels and take it out and romp on it, should stop very soon. Drop back in and update.
Old Aug 16, 2017 | 09:55 AM
75w90mantraN's Avatar
Yeah, if its white smoke, good to check the coolant levels (reservoir and rad). If it continues, prob need to replace the head gasket. I'd also just check the trans fluid at the bottom and let out a little bit of fluid drain out and see if any large metal fragments are coming out since it's been driven empty.
If its blue, hopefully it all dissipates after the correction.
As suggested, keep an eye on everything and let us know how it goes.
Old Aug 20, 2017 | 06:57 AM
Burnt off the oil after a mile or so of driving and has been running fine since. Thanks guys.
