Sponsored by: CARiD
Drop front dif and oil pan for timing?
Old Apr 9, 2017 | 10:26 PM
mattyboi's Avatar
Was reading up the factory service manual regarding timing chain removal and install. It says you have to drop the front dif and oil pan. Why is that?? 90' 4runner with a 22re.
Old Apr 10, 2017 | 03:26 PM
Utah4Runner86's Avatar
Because the timing cover bolts to the front/top of the oil pan and the bottom of head, one of which needs to be at least slightly moved out of the way in order to get a good FIPG seal when you put the cover back on. Would you rather pull the head?
If your timing guides disintegrated, it's a good idea to drop the pan anyway to clean that stuff out.
Old Apr 16, 2017 | 01:32 AM
wyoming9's Avatar
Red face
It is a personal choice I always pull the head .Most times the head gasket has failed
If the head comes off it gets a new timing chain kit
If it is time for a timing chain a failed head gasket can`t be far behind. The way my luck goes
Old Apr 16, 2017 | 12:24 PM
mattyboi's Avatar
Thanks for the input guys. Nope don't need to do timing or anything on my truck, just curious as to how to do it!
