Sponsored by: CARiD
new engine wont run, throwing code 11?
Old May 9, 2017 | 06:15 AM
Kracker's Avatar
Question new engine wont run, throwing code 11?
tested the tps its fine in all specs but truck acts like its starved for fuel ?
Old May 9, 2017 | 01:08 PM
gsp4life's Avatar
Code 11 could also be a bad ecu.
Old May 9, 2017 | 06:59 PM
Punchy's Avatar
ECU could be bad, But also not enough power.
Check all connections and if you can swap/replace the EFI relay.
Make sure the ECU is grounded good.
