Sponsored by: CARiD
93 toyota pickup 4x4 problem
Old Jul 20, 2017 | 06:49 PM
allan.selph's Avatar
i have a 93 toyota pickup Automatic 4x4 22re motor, Truck runs great until check engine light comes on. When it comes on my truck idles rough and when taking off from a stop it feels like im in a higher gear until i get up to around 40mph then it feels fine. When taking off in first gear in takes off fine but when i shift to 2nd or into drive my truck acts like its going to die. If i let truck sit for a coupl hrs then check engine light goes off and everthing is normal again. This happens usually once a month. What could be the problem???
Old Jul 21, 2017 | 10:55 AM
wyoming9's Avatar
Red face
You might want to check what code is causing the light to come on.
Do you know how to do this yet??
Old Jul 21, 2017 | 04:11 PM
ive done it before by using jumper wire and check engine light blinked . I will do it tomorrow and see what it pops up and let u know
Old Jul 22, 2017 | 06:05 AM
Terrys87's Avatar
Check for air leaks and mis-routed hoses. I have had Check Engine Lights with no codes and has been from air leaks.
allan.selph
Jul 21, 2017 06:56 AM
