Sponsored by: CARiD
Steering arm stuck
Old Jul 25, 2012 | 06:26 PM
sp543's Avatar
Steering arm stuck
I am replacing my inner axle seals and am removing the knuckle the short way, or cameo method I think it's called. I got the 4 steering arm bolts off, along with the cone washers, and am trying to remove the steering arm and it's not really budging. I did get about a 1/4 inch using a screw driver and hammer to force it up, but am afraid of doing damage with that method. Do I have to remove the horizontal tie rod that connects the 2 knuckles do remove it? Any special way or trick to getting these off?
Thanks
Old Jul 26, 2012 | 04:46 AM
waskillywabbit's Avatar
Might be stuck in the bearing. Hit it with your purse.
:wabbit2:
Old Jul 26, 2012 | 10:59 AM
sp543's Avatar
I got it off, the trunion bearings look good to me, no chunks or anything taken out of them but does anyone have a picture of a new one to compare? or a link to reasonable priced ones, a parts dealer near me wants $40plus each for them which seems ridiculous
Thanks
Old Jul 26, 2012 | 06:24 PM
rokblok's Avatar
They are cheap enough in a kit. Worth the peace of mind to me... Call Wabbit...
Old Jul 26, 2012 | 06:27 PM
sp543's Avatar
True, but I bought just about every thing I need besides those, so I rather just by single bearings instead of all the gaskets and seals that I already have.
Old Jul 26, 2012 | 06:54 PM
rokblok's Avatar
You can get just trunnions and races minus the seals and gaskets.
Old Jul 26, 2012 | 06:57 PM
sp543's Avatar
Mind posting a link where I can get them at a reasonable price? A shop near me said $38 each, Toyota dealership said $42 and those seem quite high. Couldn't find anything online with just bearings and races
Old Jul 26, 2012 | 09:02 PM
rokblok's Avatar
CruiserOutfitters.com. Kurt is an excellent guy to do business with. Been friends for many years. Since I don't know how to post links.... CruiserOutfitters.com. Top left, under Drivetrain--Lockers, gears, axles-- scroll down and you will find it.
Front Axle Knuckle (Trunnion) Bearing
4 Required per axle, Koyo Bearings w/correct taper.
Part# FA17001˟˟˟˟˟˟˟˟ - $17.50 ea.
(Fits 58-1/90 FJ40/55/60/62 & 79-85 PU/4Runner)
Part# FA20003˟˟˟˟˟˟ - $19.50 ea
(Fits 1/90-97 FJ/FZJ80/LX450).
Old Jul 27, 2012 | 12:27 PM
sp543's Avatar
Heres a pic of one of my top bearings, is the inner part supposed to be raised up a few mm?
There is no appaernt damage to it, no scrtches or gouges, and still spins and moves freely and easily. Good to re-use?
Old Jul 29, 2012 | 10:41 AM
sp543's Avatar
im working on the drivers side knuckle now, i had to remove all but 1 stud completely due to the cone washes being so wedged in and not coming out, i beleive the previous owner torqued them down way to tight and they got really wedged in there. the last stud would not back out, so i had to pry/hammer the steering arm up with the cone washer still in. I got the arm off but the cone washer is still stuck incredibly tight in the hole even with no bolt in it, ive soaked it for 2 days with PB blaster and WD40, still not coming out. i think its rusted in/bonded with the arm, my question is what should i try next? should i go out and by a torch and heat it to maybe get it to pop out, or keep soaking it in pb blaster? Im using all new studs and washers so i dont mind if this one gets destroyed.
Thanks
okamikai
Apr 30, 2018 10:19 PM
andrewtexas123
Jul 6, 2016 01:49 AM
fountain
Dec 31, 2015 06:08 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
kirkrunner
Jul 27, 2015 07:59 PM
