Sponsored by: CARiD
Broken timing chain guide
Old Aug 6, 2012 | 05:44 PM
Rld747's Avatar
So I had just pulled the oil pan off my 91 pickup to change the gasket and immediately noticed the timing chain guide sitting on the bottom in a hundred pieces. I ordered a new kit off eBay with; chain, both cam and crank sprockets, the cover, oil pump , water pump, front seal and all the gaskets. I am also ordering a new oil pump drive gear ,all 3 crank keyways.and A new distributor drive gear.
This will be my first "big"-ish motor job. I've heard that "as long as its on tdc everything is smooth." but I want to be sure....are there any other precautions I should take while doing this job? I plan on doing this on a weekend (fri/ night -Sunday) because it's my only vehicle and I need it to get to work.. Any help ,tips, tricks,or advice will be greatly appreciated .....I am new to this forum so I haven't quite figured it out yet lol...I'll post pics soon thanks
Old Aug 6, 2012 | 05:48 PM
rworegon's Avatar
22RE? Lots of threads around here on the subject. Give the search function a try.
Hope you got a quality kit.
Good luck.
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
jon.r
Jul 11, 2015 03:34 PM
shar
Jul 9, 2015 12:38 PM
