Sponsored by: CARiD
86 Runner AFM (air flow meter) issues
Old Aug 10, 2012 | 10:02 AM
kushiel's Avatar
1986 4runner, 22R-E, non-turbo We fixed the engine loping on other a thread. Now the runner will turn over and the AFM flap bangs sometimes but not others, without ever starting. When I disconnect the tube from the AFM to the throttle body and prop the flap open it starts just fine. I can reconnect the tube after a min and the 4runner idles just fine and runs. I did both resistance tests on the AFM. The AFM terminals to ground looked good. The AFM terminal to terminal tests looked ok a few were on the high side. I have a better volt meter so I will check on these this afternoon. I checked the engine codes and got the following errors: O2 sensor, AFM, AFM temperature. I also checked the brain box and everything looks good there. I suspect there is something goofy with the AFM and need to replace it. But are there other sensors plugged into the system I should check? I took a look at the wiring diagram but I am not so good with those things. Thanks, ara
Old Aug 11, 2012 | 02:45 PM
myyota's Avatar
It sounds like you have a bad AFM for sure. If the 02 sensor is original with alot of miles on it, im sure its bad or weak also. Replace it with a Denso 02 sensor, do not use a Bosch 02 sensor, they don`t work in toyotas.
You can get an 02 sensor here. www.densoproducts.com
Team420
Jan 12, 2021 04:57 PM
puffin04
Jul 10, 2015 09:17 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
shepsyota
Jun 25, 2015 08:36 AM
