Sponsored by: CARiD
4runner wandering at higher speeds
Old Apr 19, 2010 | 06:38 AM
Superflie's Avatar
All the searching i've done on this topic refers to 3rd gen 4runners. Mine is a 1990 4runner with a 4" suspension lift and 33x12.5 18's on it, the rear lift is a longarm, front is still IFS unfortunately. I purchased this about a week ago and right around 60-65 on the freeway it starts moving side to side, almost like a snake swimming in the water. It's not predictable at all and sometimes doesn't do it for a bit, but it does happen frequently. I took it in last week and had the suspension gone through and my CV axles were both bad as well as one tie rod end. Changed those out this weekend on my own of course and Its still the same. Replaced the Steering stabilizer as well. The articles I have found on here have talked about 2 things, steering rack bushings and loose body mounts or bushings. As far as I can tell steering rack bushings are for 3rd gen 96 and on. Could it really be the body mounts or bushings on this? Or could there be something else I'm missing. I am taking it in this week to get the alignment and balancing on the tires ensured.
Old Apr 19, 2010 | 07:21 AM
dropzone's Avatar
Fossilized
smart thing getting the suspension etc checked out. Do the tires show any obvious signs of being out of balance?
one thing i notice on my truck is that some of the wandering it does is also relative to the condition of the road...Local roads it is fine, get it on the highway where you can see an actual rut from the high amount of traffic/trucks and it will wander a bit more.
Old Apr 19, 2010 | 07:24 AM
Superflie's Avatar
This is pretty severe and it seems to happen randomly. Highway speeds but on any road
Old Apr 19, 2010 | 07:26 AM
Superflie's Avatar
i haven't been able to find body mount bushings for a 90 4runner either. What am i missing?
Old Apr 19, 2010 | 12:29 PM
Superflie's Avatar
ok, i found these ones, damn this site kicks ass
http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
Old Apr 21, 2010 | 07:25 AM
dropzone's Avatar
Fossilized
4crawler has some great info...it is nice when he chimes in a thread
Old Apr 21, 2010 | 05:37 PM
85-in-va's Avatar
check ur swaybar and make sure the endlinks arent broken, also did u have it lined up after you replaced the frontend parts, if everything looks good try rotating the tires. there are so many things that could cause it, maybe excessive play in steering box, just a few ideas, good luck
Old Apr 21, 2010 | 05:48 PM
B4Runner's Avatar
The sway bar wouldn't cause that. Many members, myself included, have taken our sway bars off. Besides for the flex increase, it only creates more body roll, which is no biggie on these trucks.
Old Apr 25, 2010 | 07:21 AM
old mud dog's Avatar
it sounds like you have done it all sheck the stearing box for to much play they do where out more so with big tires .... after checking the tires for uneven ware look at
the air presure if there over inflated it will do just that wonder !
Old Apr 25, 2010 | 08:47 AM
tc's Avatar
tc
Alignment - in particular caster angle.
When you take it in, ask them to max out the caster ... good luck getting them to do it, but if you don't ask, they for sure won't even try.
Old Apr 26, 2010 | 08:48 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
It's a lifted 4Runner guys... Come on... "Lifted" means a person of unknown intellect has messed with what the factory nailed, on the 1st try...
I'm going to say rear panhard bar... You want to see it nice and level, IF you even have one. And the tires should have equal room to the frame on both sides. The axle jacked to one side indicates the drop brackets not being used, and the pan hard bar is too short.
A lot of times when they get lifted ppl forget about the bar, b/c they think it's not important.
So take a pic of the rear, or even the front... Pics help us...
And another thing. There is nothing wrong with IFS so I don't get the "IFS, unfortunately".
And if you're dogging it now, just wait till you get a leaf spring SFA together with coil springs on the back... It'll be tight in the front, and loose as a goose from the coils in the rear.
So now you're gonna learn after you do all this, the same thing most guys with SA 4Runners do, which is convert the rear to leaf spring... Only I'm telling you now instead of learning this AFTER...
So now your $1,000 SA prodject just turned into $2,000 and a ton of down time while you weld the mounts and get the geometry right...
When you could have just left the IFS alone and it would have been fine.
Old Apr 26, 2010 | 08:54 AM
Lumpia's Avatar
I run 33x12.5's and I wander a bit too. Mine is caused by the previously mentioned ruts in the road, the tire is just wide enough it won't sit down in the rut, and wants to bounce in and out all the time.
Old Apr 26, 2010 | 01:33 PM
thats good valuble info !. thanks
Old Apr 26, 2010 | 01:41 PM
n8buddy's Avatar
my truck does the same thing had it checked out and the mechanic said my idler arm had some play so you could check that out
MTLroadierunner
Jul 15, 2015 12:58 PM
Nickdigg
Jul 7, 2015 06:04 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
