Sponsored by: CARiD
Shifting into 4WD
Old May 2, 2010 | 02:18 AM
mldave's Avatar
Shifting into 4WD
I'm totally dumb on this stuff,so here goes my ???? 85 5 speed,manual hubs.What are the step by step procedures to shift into 4WD,on road and off road?
Old May 2, 2010 | 05:08 AM
xxxtreme22r's Avatar
1) turn hubs from free position to lock position, the positions are labeled on the hubs. Full clockwise for lock and full counter clockwise for free.
2) shift 4wd (transfer case) shifter (the shorter of the two shifters.) into 4hi or 4 lo. Positions also listed on the shifter. For 4 low you would move the shifter all the way down then to the right then up to the top. For 4 high all you have to do is move the shifter all the way down.
step 2a) Never move the transfer case shifter to/from 4lo/4hi to 2wd and vise versa when moving.
step 3) enjoy your 4WD.
Old May 2, 2010 | 06:05 AM
same with mine gnarly they are only like 1/3 turn, I think the only ones I know of that are 7/8 turn are Warn heavy duty's not sure if they are like that on the toyotas but my bronco had then and were 7/8 of a turn. I also used synthetic on my hubs when I did my brakes.
Old May 2, 2010 | 09:59 AM
mldave's Avatar
Does one have to shut off the motor and put on the E-brake before the above steps or can it be done with the tranny in neutral with the motor running?Also what speeds are tops for 4 WD in high/low?.....thanks for the info.
Old May 2, 2010 | 02:09 PM
eddieleephd's Avatar
I know on the newer trucks you can go from 2wd to 4hi up to 50 mph. you just have to lock the hubs before hand and never shift to or from 4lo when moving, you must be at a full stop and use the clutch!!
Old May 2, 2010 | 05:11 PM
Originally Posted by Gnarly4X
I don't believe that "speed" is the factor when in 4-wheel low or 4-wheel high, it's engine RPM for the gear you're in, just as it would be if your were NOT in 4-wheel drive.
the RPMs will be the same in 4hi as 2wd but like doubled in 4lo
Old May 2, 2010 | 05:35 PM
Matt4Running's Avatar
I like my ADD,dont have to get out and do anything just clutch and shift.I usually stop,although I dont have to(paranoia).
Old May 2, 2010 | 05:59 PM
4Crawler's Avatar
With the front hubs locked in, you can shift between 2H and 4H most any time and at most any speed, as long as the tires are not spinning and you are not accelerating hard. No clutch needed, just ease off the gas and pull the t-case shifter. Between 4H and 4L, you need to be at close to a stop or else double/triple clutch and rev-match the shift.
mskalmus
May 28, 2017 07:51 AM
Mudlover
Sep 2, 2015 03:50 AM
mund1011
Aug 16, 2015 07:10 AM
jgwerth
Jul 16, 2015 03:23 PM
crashburnoveride
Jul 10, 2015 06:39 AM
