Sponsored by: CARiD
Front Axle popped out of Differential
Old May 12, 2010 | 09:52 AM
Bugzuki's Avatar
I got a 91 pickup and during some rain I tried moving it around in some light mud. I kept getting a back wheel spinning, so I put it in 4wd. It did not seem to make a difference. I thought maybe the hubs weren't locking or something.
After more inspecting I found that the passenger side axle shaft is not ingaged in the differential. I don't know how long this has been driven this way.
My question is how are these held in place? Since they have the bolt on CV shafts I would think that it was held in with more then a snap clip. Can I just push it back in and good to go, or do I need to take the differential apart and put some retainer back in place?
I figure I will need to eventually replace the bearings and stuff since I don't know if the previous owner got water in the diff, and don't know if all the oil has leaked out.
Do they make lockers for the IFS? What LSD fit the back axle?
I did try to search, but did not know what to search for. So, I didn't get any answers that were even close.
Old May 12, 2010 | 10:00 AM
874runnersr5's Avatar
you can see the studs on the diff, and kinda see the housing of the cv joint.. mind you this pic my cv joint is done..
They do make lockers for ifs, but its aftermarket 7.5" lockers. I think you can retrofit a celica lsd to your rear diff, or do the elocker mod.
Old May 12, 2010 | 01:13 PM
Bugzuki's Avatar
Thanks for the reply. On mine the flange with the bolts (on Passenger side) is pulled out of the differential. The bolts are all still done up to the CV joint. I can take a picture tonight.
I have an 87 Supra LSD rear end, would that work, or does it have to be out of a solid axle? My wife is tire of spinning one wheel when she tries to go. I don't know what an elocker is. I will have to search.
Old May 12, 2010 | 01:15 PM
SpecialScottie's Avatar
Elockers only fit 8 inch axles
Old May 12, 2010 | 01:47 PM
camo31_10.50's Avatar
anddddd what size is all toyota pickup and 4runner rear axles....oh yea that's right, 8"
i have no other useful information about the problem though lol...lockers however i know a little about, lots out there for the IFS..but a aussie would be best. atleast that's the general idea lol
Old May 12, 2010 | 01:48 PM
yes please, take pics...that will help us out
Old May 12, 2010 | 02:56 PM
dewiseman's Avatar
I had a 90 pu and the axle shaft was held into the dif. by a C-clip. Make sure the clip is still on, line up the splines and give it a good rap with your hammer and it should slip back into place.
Old May 12, 2010 | 02:58 PM
Bugzuki's Avatar
Cool I will give that a try
Thanks
Old May 12, 2010 | 04:46 PM
really? everyone is 8" eh..
Old May 12, 2010 | 04:48 PM
i meant to say all four wheel drive toyota pickups and 4runners of the '79-'95 year range lol
i shoulda been more specific lol my bad
Old May 12, 2010 | 05:02 PM
haha, there ya go!
Old May 12, 2010 | 07:26 PM
Bugzuki's Avatar
So here is what I was referring to. Notice how the axle is sticking out of the differential. It was more then that before I pushed on it. I could not get it to come back out farther.
It took me a little bit to find the fill plug, it was covered with mud and grease.
You have to take the front skid plate off to get to it.
Remove:
Then the fill plug is on the front diff cover:
Now I have 4WD. But, When I tried to spin the tires on gravel in 4 high the clutch slipped. I guess I know what my next project will be.
I also have to track down some oil leaks. But, I got the truck for free so I cannot complain. Oh, in the fill plug picture you can see the new steering bar the was replace as a recall item. I also got a free alignment and wash with it. That was a good deal.
Old May 13, 2010 | 05:27 AM
meswoleshane's Avatar
Mine did this...
Old May 13, 2010 | 09:08 AM
Jay351's Avatar
http://www.gearinstalls.com/supralsd4.htm
Old May 13, 2010 | 02:12 PM
Bugzuki's Avatar
Originally Posted by meswoleshane
Mine did this...
That is exactly what mine looked like before I pushed it in by hand. Not as dirty though.
I had to take the wheel off and use a long tube and big hammer to get it back in. Works good now. Thanks for the reply.
Originally Posted by Jay351
That is also exactly what I was looking for. I just happen to have an 87 Supra Turbo rear LSD sitting in the shop. Now I know it will fit and have a resource for the install.
I wanted a LSD on the back instead of a locker, that way there is always more grip in the back. And it is useable on the road.
Thanks everyone for the great replies.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
PlayAwhile
Jul 20, 2015 11:36 AM
