Sponsored by: CARiD
How long does it take do do a timing chain?
Old Apr 28, 2010 | 02:50 PM
whutface's Avatar
Just wondering how long I can expect it to take for me and a buddy to do the timing chain on my pickup. I'm gonna be doing it at the shop at my college and ill have maybe 4-5ish hours to work on it and if I don't get it done its gotta sit for 2 days before I can finish it.
Also any seals or anything I need to remember to get before I tear it all apart and need to go get more /waste time?
Thanks guys
Old Apr 28, 2010 | 04:04 PM
SoCal4Running's Avatar
Should be enough time for a 1st timer.
Are you getting a kit? Either way you need a crank seal , timing cover seals and some sort of RTV. Also helpful is some sort of degreaser and a piece of cardboard to put all the bolts thru in the location they came from on the motor (a map of the timing cover)
Old Apr 28, 2010 | 04:12 PM
whutface's Avatar
Yeah I'm planning on getting the enginebldr kit,
It seems like it could take a while.. With gasket scraping and cleaning. Probably some time spent just staring at it lol
Old Apr 28, 2010 | 04:17 PM
874runnersr5's Avatar
are you going to drop the front diff?
Old Apr 28, 2010 | 04:22 PM
whutface's Avatar
I don't know I was gonna see how the guides looked. I imagine they might be torn up Its got 226,000 and I don't know that its ever been done.
Is that difficult/time consuming?
Old Apr 28, 2010 | 04:23 PM
toyota4x4907's Avatar
You either have to loosen/remove the head or drop the front diff
Old Apr 28, 2010 | 04:24 PM
whutface's Avatar
Really I thought you only had to do that if you were gonna drop the pan? I don't wanna mess with the head
Old Apr 28, 2010 | 04:29 PM
mistergarrett's Avatar
Personally i agree. U cant squeeze a TC in with pan bolted up and the head torqued down. I tried while doing a HG change and damaged the HG. So I pulled the head again and replaced the gasket. I didnt want to do all again.
Some others might know of a way to do it, but sorry Im not that one.
Old Apr 28, 2010 | 04:59 PM
seanmearse's Avatar
Granted mines an 84, i dropped the pan, pulled all the bracketry, pulled the timing cover, took an hour lunch break, started again, got her back together, it took me around 6 hours, BUT, i was dilly-dalling around, taking my time. But if you are missing any part of the guides or tensioner assembly- pull the pan. Also, dont forget the "hidden" bolt!
Jun 1, 2021 01:51 PM
redneck17
Jul 17, 2015 07:44 PM
msane99
Jul 11, 2015 08:08 PM
Vargntucson
Jul 4, 2015 12:15 PM
