Sponsored by: CARiD
Rhino Liner advice...
Old Sep 20, 2014 | 01:16 PM
Snoyota's Avatar
Can anyone recommend a good wax/polish that doesn't leave white shizz on trim or rhino lining? Also has anyone used UV protectant on there rhino lining? If so did you apply after or mix in with the rhino liner? Mine fades out and I have been re-applying every year or two. I used the Hercu-Liner brand. Any advice would be greatly appreciated... Please and thank you!
Old Dec 3, 2014 | 06:16 PM
WarWagonGunner's Avatar
I don't know of one that dosent turn things it's not meant to go on white. But I do have a little trick I use on my charger. My truck is for shooting and rompin around in the mountains so I don't polish, but my charger I do often. I normally put a but of Vaseline on the things I don't want the wax on, I'm careful around those things when applying wax and then also when buffing by hand. Also I wax the car like I color a picture, do the outline first then the middle after. U can also use painters tape. Little less messy but could cause problems too. And with the vasiline... After ur done waxing it, give it a nice quick bath with the pressure washer and u should be good to go.
terminator
Oct 13, 2021 10:13 AM
87SR5justin
Sep 29, 2015 02:50 PM
Sep 4, 2015 09:27 AM
58rennur4
Aug 4, 2015 08:49 AM
KBar
Aug 3, 2015 11:12 PM
