Sponsored by: CARiD
Head gasket nightmare
Old Dec 1, 2014 | 02:51 AM
Sodak.gold's Avatar
I need a little help confirming that my head gasket blew. Driving home from work Saturday night truck was at op temp till 5-6 miles from home
Then saw gauge start to rise. At a stop light the truck died( that was normal cause of hot idle issue) next light the gauge was higher but still not really close to redline third light when trying to start truck to go it looked like I lit my exhaust on fire smoke just billowing out of tail pipe
Started to run a little rough after that
At that point I was trying to get to a parking lot
Missed the light and when I started the truck it started hard ran like crap and blew copious amounts of smoke out the tail pipe. I barely got it into a parking lot 70 feet from the corner
I got out and the smoke looked like I set something on fire. Checked under the good and no real noticeable steam bled off the radiator and waited a few minutes and saw no coolant at top of radiator waiting on tow got in truck and had a strong coolant smell
Next morning put watt in radiator and tried to start it just cranked. I think it is dead I just need confirmation thanks
Old Dec 1, 2014 | 04:40 AM
rworegon's Avatar
What engine? Yes, sounds like HG went and possibly additional damage.
Old Dec 1, 2014 | 05:09 AM
Sodak.gold's Avatar
3.0 v6
Old Dec 1, 2014 | 10:05 AM
rworegon's Avatar
How does the coolant look? How does the oil look? What does the underside of the oil cap look like?
Do a pressure test of the cooling system and a leak down test on the cylinders.
Old Dec 1, 2014 | 11:01 AM
Sodak.gold's Avatar
Thanks it is definitely a blown head gasket there is zero pressure and no cylinder compression thanks again for all the info
Old Dec 1, 2014 | 11:31 AM
rworegon's Avatar
Ah, bummer. Post up what route you go to fix it and if you find any other internal damage.
Good luck!
Old Dec 2, 2014 | 03:26 PM
oilspot's Avatar
My votes for head gasket! Plugs fouled with coolant= she aint gonna wanna start this morning.
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
themightykhoner
Aug 11, 2015 07:37 PM
Coreyr384
Jul 10, 2015 11:13 AM
