Sponsored by: CARiD
Clutch/flywheel question
Old Jul 2, 2008 | 06:31 AM
jddelrosso's Avatar
So I shot from the hip when purchasing parts to swap my motor and figured I may as well swap the clutch flywheel and pressure plate while the motor was out of the truck. So I bought an excedy kit off of EBAY thinking I would be set. I looked at the kit again today for no reason other then boredom and noticed that it says the flywheel is only good for 89-95 2wd trucks and 89-92 4wd. I have a 94 4wd truck, but the motor and tranny I am using came from an 87. I assume then that the kit will work but before I install it I would like to know if I am correct.
Oh, and now that I think about it is there anything special I need to do to swap the older transmission into the truck or should everything bolt up?
Thanks for any info
Jeremy
Old Jul 2, 2008 | 04:54 PM
FredTJ's Avatar
Thanks for any info
Jeremy
I don't have any answers to your specific questions however what you are doing is illegal and you're opening yourself up to a possible $2500.00 fine.
Fred
Old Jul 2, 2008 | 05:22 PM
Josh.Photo's Avatar
Fred. What is illegal about what he wants to do?
not trying to be a jerk or anything, but an honest question.
Old Jul 2, 2008 | 05:30 PM
Jay351's Avatar
Please tell me what he is doing that is illegal. I would really like to know.
Im assuming you are running a 22re (or possibly a 22r), what transmission though?
Old Jul 2, 2008 | 05:38 PM
crews462's Avatar
I'd be curious what's illegal as well.?
Old Jul 2, 2008 | 05:43 PM
89silverpu's Avatar
Yeah? Its illegal to put the wrong parts on a vehicle?
Old Jul 2, 2008 | 05:44 PM
FredTJ's Avatar
It's illegal to put an engine from an older model year into a newer model year vehicle. EPA, emissions, etc.
You simply can't do that.
Fred
Old Jul 2, 2008 | 05:55 PM
89silverpu's Avatar
Fred
Huh...never new that, sorta makes sense though, but does it matter if its the same engine?
Old Jul 2, 2008 | 06:01 PM
FredTJ's Avatar
Doesn't matter.
If you think about it for more than a nano second or two, you'll realize that the emission on the '94 engine is a lot less than that on the older one.
Fred
Old Jul 2, 2008 | 06:03 PM
crews462's Avatar
Does that make it a state by state law? Vt doesn't test emissions upon inspection (at least on my 89)
Old Jul 2, 2008 | 06:12 PM
FredTJ's Avatar
NO, it has nothing to do with a state testing or not.
IT IS A FEDERAL, EPA, LAW
Fred
Old Jul 2, 2008 | 06:15 PM
crews462's Avatar
thanks fred
Old Jul 3, 2008 | 06:21 AM
jddelrosso's Avatar
I as well thought that was a state by state law. I am also not worried though because my dad does NY state inspections for me and at the same time on the 94 it is just a safety inspection so they only check out lights, brakes and whatnot. So thank you for the warning, and Ill watch my back for the legal problems I may run into.
Back to the original issue, it is a 22re motor, I just looked at the old and new flywheel side by side and did not see any real difference, Im going to examine the clutch and flywheel tonight, what should I look for in order to tell if they are the same or different. Thanks
Jeremy
Old Jul 3, 2008 | 02:46 PM
FredTJ's Avatar
Jeremy
Also, if you ever sell the vehicle you could have a problem.....
Fred
Old Jul 3, 2008 | 07:02 PM
jddelrosso's Avatar
I doubt it matters but I am going to use the entire intake from the newer truck anyway, which includes the egr system...
again, I doubt that matters
Jeremy
Old Jul 3, 2008 | 09:44 PM
84socal's Avatar
a 22re is a 22re there is little to nothing they changed on the blocks the only difference u might have is the vac lines and or some plugs and as far as the clutch and flywheel are concerned im pretty sure its all the same good luck bro
Old Jul 4, 2008 | 05:18 AM
jddelrosso's Avatar
thanks, I hope you are right.
Jeremy
Old Jul 4, 2008 | 01:17 PM
Josh.Photo's Avatar
Fred. How are they able to tell? Do they go off the engine case numbers? As far as i knew, as long as the engine is in the same family. and has the same evap system it should be ok. I would think a 22re swapped with a 22re should be just fine. especially if its an older engine into a newer vehicle, that older/"dirtier" engine is going to be held to the newer/higher/cleaner emissions standard of the newer model vehicle.
again, im no expert on the issue. but i do have a friend who is a certified CA smog tech and i think this might be a question ill ask him.
Old Jul 4, 2008 | 05:37 PM
Jay351's Avatar
Alot of what we do is not legal. Who cares? The monkeys at the inspection place won't know the difference from a 22re from 87 and a 22re from 94...
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
