Sponsored by: CARiD
Fuel Tank Part?
Old Jul 14, 2008 | 10:33 AM
Chainlink's Avatar
Fuel Tank Part?
Ok I have a 93 5speed 4x4 Standard cab Pick up 22re and I have had a heck of a time, The unit on the fuel tank that has 3 tubes running from it needs to be replaced. I had gotten one many years ago but it seems now they only sell the pump related to it (parts store I frequent). Is this a dealer item only as my memory is fuzzy.
If you know what its exact name or part number I would be very thankfull. Cheap is the aim here as its a true beater.
Chain
Old Jul 14, 2008 | 08:55 PM
Chainlink's Avatar
no one, ouch
Old Jul 15, 2008 | 03:22 AM
tulsa_97SR5's Avatar
Hey, that part is a pain to replace. I believe it's just called the fuel pump bracket, and I couldn't find an aftermarket one to save my life. I almost ordered through toyotapartsales.com but found a complete used tank for less that was in better shape than mine, try these part numbers, depending on the size of your tank
23206-35140 AND ONE FOR THE 65 LITER #23206-35160
I think it would be maybe $90 or so?
Old Jul 15, 2008 | 09:46 AM
Chainlink's Avatar
Thanks, I replaced one years ago and believe if memory was right I had 2 of the 3 screws break, what a pita.
Old Jul 15, 2008 | 11:27 AM
KrysToy's Avatar
Don't know if this is what you mean for sure but I had a prob with mine last year two of the tube ends were corroding off, one was the vent line and the other went to sending unit, we took it off the tank, drilled out tubes and replaced with flared copper tubing, regasketed and fastened back down with small sheet metal screws into original bolt holes. Dunno, just a thought, worked for me.
Old Jul 15, 2008 | 02:10 PM
Chainlink's Avatar
Maybe, its real rotten. I may have a line on one from another member which would be nice.
Those without salted roads are so frigging lucky, When I was out west I was mighty envious of the old rigs that were in awesome shape. Around here to see a vehicle more than 10 years old without some issue is almost unheard of. The south for the most part just as lucky.
Old Jul 17, 2008 | 10:28 AM
Chainlink's Avatar
Well the part I hoped for didn't pan out, so part or number search still continues any ideas?
Old Jul 17, 2008 | 06:57 PM
bruzer1123's Avatar
I think you are in luck. I replaced the fuel tank bracket (which sounds what you need) in my truck a couple years ago (sept 06). I believe these are the correct numbers-I managed to dig them up from my email from trdparts4u.
23206-35250 $ 114.31 for the fuel tank bracket
77169-14010 gasket $3.05 (gasket for the fuel tank bracket)
93381-15010 x7 $ 0.55 each (screws for the fuel tank bracket-I think you need six but I can't recall that)
Hope this helps
Old Jul 18, 2008 | 04:09 PM
Chainlink's Avatar
Hope this helps
Thanks
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
skoti89
Jul 8, 2015 12:05 AM
