Sponsored by: CARiD
Egr problem. 95 22re engine miss,stumble.
Old Jun 12, 2008 | 11:20 AM
iselloil's Avatar
Cool Egr problem. 95 22re engine miss,stumble.
Take note,everything is new,all egr parts,engine.At normal engine temp, I get a bad engine stumble around 30 to 50 mph.Un-hook the egr,it goes away,move the vaccume lines on the modulator,move e and r to the opposit positions,the stumble goes away.Plug up the vac lines to the EGR and the stumble goes away.All egr parts are new toyota parts,all tune up parts are new,engine has 3000 miles with a R-V cam.I traced all of the vac lines and made sure no leaks,and all lines are in the right spot. ANY Ideas????????????
Old Jun 12, 2008 | 12:49 PM
4Crawler's Avatar
I think on the '95 there is an ECU-controlled Vacuum Switching Valve that sends vacuum to the modulator. Might want to check that out per the testing procedures in a factory Service Manual. Maybe it is stuck on or something else is telling the ECU to turn it on at the wrong time.
Old Jun 12, 2008 | 04:54 PM
iselloil's Avatar
modulator switch
If its the one on the valve cover with the one way valce on it,That is the one componet not changed.
Old Jun 12, 2008 | 04:55 PM
iselloil's Avatar
modulator switch
If its the one on the valve cover with the one way valve on it,That is the one componet not changed.
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
