Sponsored by: CARiD
Amount of Oil/Block
Old Jul 6, 2008 | 10:12 AM
94_yota_pickup's Avatar
Amount of Oil/Block
Ok my block is stamped 22r but the valve cover says 22re on it so is it a 22re or 22r? Also is the oil pan different from a 22r to 22re because i changed my oil and it takes 7 qts of oil to fill to line on dipstick or do i have the wrong dipstick?
Old Jul 6, 2008 | 10:17 AM
TOYOTA 1's Avatar
if its the stock motor/efi then yes it is a 22re.
as for 7 quarts... umm it should only hold 4/4.5 qts.
take a pic of the oil pan and dip stick and i can tell you if there stock or not.
Old Jul 6, 2008 | 02:08 PM
Oil
Well could anyone send me a picture of what the stock oil pan on a 22RE looks like. I think is not the stock one, it measures 6 3/4" at the deepest part on the pan. The dipstick is 22 1/4" from bottom to where it stops on tube. Im thinking that I have a bigger capacity oil pan with it taking 7 qts to fill.
Old Jul 7, 2008 | 06:09 PM
TrikeKid's Avatar
Your dipstick is probably like mine and wrong. My problem being the dipstick tube is too long. 22R's only take 4.9 quarts bone dry. Mine is the same way, I had 7 and a half quarts in it to make it read full, started smoking like it blew the hell up. I just put the right amount in and made a new mark on the stick.
matmattmatthew
10
Feb 9, 2021 04:15 PM
puddlepirate
Jul 30, 2016 06:29 PM
Corvoid
Dec 11, 2015 11:21 AM
voiddweller
Sep 28, 2015 11:21 PM
jacked_72
Sep 14, 2015 03:31 PM
