Sponsored by: CARiD
22r carburetor issue -need lil help
Old May 4, 2009 | 07:51 PM
916yota's Avatar
Whats up everyone im new on this forum and i have a 89 pickup 2wd with a 22r in it. I bought it friday and it ran great all weekend till today. it starts and stalls. It runs on brake clean so that made me go towards the fuel pump. i pulled the hose to the carb off and cranked the engine over and the fuel pump is getting fuel to the carb. and the carb is getting fuel out to the intake too. truck has 160k miles. do you guys think i should just rebuild the carb or know of anything else i should check. i have a feeling something to do with the idle in the carb has gone bad.
Old May 5, 2009 | 01:16 PM
Flash319's Avatar
If you are getting fuel then I would be looking at something electrical, cap, plugs, rotor, coil.....
Old May 5, 2009 | 02:08 PM
abecedarian's Avatar
The fuel level in the float chamber should be in the middle of the sight glass on the side of the carb. If it's not, either too high or too low, there's a chance the float is saturated or sticking or the needle is not (un)seating properly causing you to run lean or flood out. If the truck sat for a while, anything's possible. There could've been some sediment in the float chamber that came loose and is now clogging a jet, the linkage could be sticking, etc.
I'd check the fuel filter as well as look for vacuum leaks before diving at the carb though. If nothing else appears wrong, you might be able to dissasemble and clean the carb but if you're that far into it a rebuild would probably be a good investment just so you know things are good and reduce your chances of having to tear it apart again.
Old May 5, 2009 | 03:53 PM
916yota's Avatar
yea sure enough the float is empty. I guess either way im gonna replace the fuel filter and hope that its just clogged and that the jets arent clogged. I'll probaby end up having to tear it apart cause of crap over the years in the fuel.
Old May 5, 2009 | 04:00 PM
Before you go too far, the float being empty 'obviously' could be an issue with the float and/or needle valve. But it could also be an issue with the fuel pump.
So maybe disconnect the fuel line from the carburetor and have someone crank the engine while you put your thumb over the fuel line from the pump and see if it can squirt fuel out between your finger and the pipe.
Make sense?
It's not that you want to bury your finger in the end of the pipe but maybe just enough to hold back 3-5 PSI pressure.
Old May 5, 2009 | 04:04 PM
916yota's Avatar
i already checked the pump. i went there first cause of the car running fine on brake clean. the pump is getting the fuel to the carb fine. its been so long since ive messed with carbs. Now is the needle valve easy to access on the carb.
Old May 5, 2009 | 04:45 PM
pull the top off the carb and be careful. there is a gasket around the horn, float bowl and such. if it tears be prepared to replace it. (which is why I said if you're going to tear it apart you might as well rebuild it.)
Old May 5, 2009 | 04:46 PM
and if the pump was getting fuel to the carb 'fine' the float should be filled properly, no?
Old May 5, 2009 | 04:48 PM
yeah, a catch 22 question.
Old May 5, 2009 | 04:59 PM
xzyragon's Avatar
that's a terrible book...
and @ op... welcome to forum, and behold, another outnumbered 2wd owner
Old May 5, 2009 | 05:24 PM
/me owns (rather shares ownership with my wife) a 91 22re Xtra cab automatic 2wd.
Old May 5, 2009 | 05:41 PM
916yota's Avatar
yea before i saw what u said i looked up a service manual and i tore the air horn assembly off and took the needle valve out and cleaned it with carb cleaner i also cleaned out the inside there and now the float is filled properly but car still starts and stalls. im starting to think a jet is plugged
Old May 5, 2009 | 05:44 PM
916yota's Avatar
thanks bro and yea i bought this thing off a 75yr old guy. im into mini trucks and this is my new project. i just crashed my 11 sec 4cyl street car so i figured id build something slow this time
Old May 5, 2009 | 06:24 PM
do it right and you can pull 1000 HP out of the 22r
Old May 5, 2009 | 07:39 PM
916yota's Avatar
well i pulled out all the jets and carb cleaned everything and now it starts and runs with me giving it gas which is more than it used to do so i turned the idle up a lil and i got it to run without giving it gas but runs very poorly. thinkin i should just rebuild carb replace fuel filter and call it a day
kazuya2416
Apr 5, 2024 02:17 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
luckypig44
Jul 19, 2015 11:25 AM
smiley52
Jul 11, 2015 05:16 AM
