Sponsored by: CARiD
88 4runner with 37s
Old Apr 14, 2009 | 05:30 AM
mytoy6970's Avatar
88 4runner with 37s
How would i go about geting more power from my 4runner with 37in tires
Old Apr 14, 2009 | 05:43 AM
gilby4runner's Avatar
Have you changed gearing?
Dan.3's Avatar
using the tornado in your air intake
Old Apr 14, 2009 | 05:49 AM
Junkers88's Avatar
I hear that hydro-dynamic injection gives like 1000 hp.
Old Apr 14, 2009 | 06:19 AM
99SR5's Avatar
throw a 5.0 in it or a 3.4
Old Apr 14, 2009 | 06:32 AM
tj884Rdlx's Avatar
put a few more hamsters in each wheel. with a 37, you can fit about 100 of em.
if that doesn't work, step up to 5.71 gears, then look into a motor swap. drop in a 4.0 lexus v8!
search for the things i just mentioned in bold and you'll find a lot of info here on both mods.
in fact, this thread has great info:
https://www.yotatech.com/forums/f116...ighway-131525/
Old Apr 14, 2009 | 09:48 AM
mytoy6970's Avatar
No i have not changed the gears what would be good ones to go with alot of people are useing 5.29s
Old Apr 14, 2009 | 10:05 AM
89silverpu's Avatar
Idk about a v8 and 5.71s haha
But in all seriousness, 5.29's or 5.71's will be the only way to get close to the stock power. Some people don't like 5.71's because they think they are "weak" but from what I've heard as long as they're set up properly they're just as strong as 5.29's.
Don't waste your money on engine "performance" mods. They don't work on Toyotas unless you have a super charged 3.4.
Old Apr 14, 2009 | 12:37 PM
94sasyota's Avatar
go with the 5.29s and see how it is after that if its still not good motor swap
Old Apr 14, 2009 | 01:01 PM
Welcome to YT by the way
Old Apr 14, 2009 | 07:18 PM
mytoy6970's Avatar
Wanted to thank all of you that replied to my questions iam new to this site and dont know how to navigate around the site yet but am learning thanx again all Michael
Old Apr 14, 2009 | 07:26 PM
mattaway's Avatar
i 2nd the tornado. you wouldn't believe the power gain you'd get from it. it's just an excellent product all around, can't really go wrong with the tornado.
EDIT: forgot to mention i've had one in every one of my vehicle so far.
Old Apr 15, 2009 | 05:17 AM
mytoy6970's Avatar
im going to upgrade my air intake with a cold air intake system can i still use the tornado with the new system
Old Apr 15, 2009 | 06:12 AM
Do some searching and see what others have done as far as intake mods. You turely wont get a "cold air" system. If you really want that look into swapping the intake and battery. Keep in mind that the 22re isnt the most powerful engine out there. Gearing will be your biggest help.
Old Apr 16, 2009 | 05:56 AM
mytoy6970's Avatar
what kind of intake and battery do you sugest and were would i find the gears at
Old Apr 16, 2009 | 06:02 AM
Swapping the position of the air intake and battery. This way it is not pulling air over the top of the radiator. I have seen a few on here do it. Just a thought.
As far as your gears are concerned....I am not the man to ask. I am sure that someone will chime in.
Old Apr 16, 2009 | 07:54 AM
olharleyman's Avatar
If you go 5.71's which would be best for the 37's look to zok to set them up he's the best I have seen or heard of gearinstall.com I believe he sells gearing as well.
He also is a member here and if you use the search button look for zuk I am sure you will find post's from him explaining how he tested 5.71 vs. 5.29 and concludes how they both hold up and how they both last ect.
Old Apr 16, 2009 | 06:12 PM
89silverpu's Avatar
Here it is
http://gearinstalls.com/410suck.htm
Old Apr 17, 2009 | 04:44 PM
mytoy6970's Avatar
Is zok located in portland oregon area or near by atleast it sounds like you all like the 571 gears nover 529 for the 37 tires iam running ur information is very helpfull thanks
Old Apr 17, 2009 | 08:08 PM
Trustyrusty's Avatar
Heres some tips...
-Spell Check, worked for me..
-Searching
-If you don't know what parts to get, you don't even need to THINK about buying ANYTHING.
-Read until you understand
Seems like we spoon feed people around here.. Can someone do a writeup on searching and make EVERY newbie read it before they can even post? and then an Insta-Ban if they dont..
IF you have 37's and want more power, obviously get gears, if you have a Toyota with a 4 cylinder and want power, you got the wrong vehicle dude, them engines came outta friggin fork lifts..
