Sponsored by: CARiD
solenoid / starter help!?
Old Mar 22, 2009 | 04:58 PM
surferkid26's Avatar
alright so im pretty sure my solenoid is bad because i put the key in the ignition and all it does is click! i know where my starter is so when i go to pull it it is buried in the abyss off AC lines and whatnot!!! so pissed how hard is it going to be to pull this starter on my 95 4runner 3.slow i dont want to pay $300 to have someone else do this if you can help it would be very appriciated
Old Mar 22, 2009 | 04:59 PM
904_runner's Avatar
there is an access pannel on the passenger side fender pannel..
Pull that off and it should make it easier.
Old Mar 22, 2009 | 05:05 PM
yeah i did that and everything but there are so many hoses in the way it is ridiculous and i really dont want to take off all those pessurized hoses
Old Mar 22, 2009 | 05:06 PM
904_runner's Avatar
When you pull it you are most likely going to have to reach up from teh bottom and pull it down..
Old Mar 22, 2009 | 05:10 PM
alright so i dont take it out from the side do it from the bottom but should i just unhook everything from the side and pull it from the bottom?
Old Mar 23, 2009 | 04:52 AM
lookin4yota's Avatar
I know this is too obvious, but can you jump it? Usually this is just a low battery symptom.
-John
Old Mar 23, 2009 | 09:20 AM
that was the first thing i tought and check the battery and even charged it and cleaned all the terminals it didnt work
Old Mar 23, 2009 | 09:25 AM
904_runner's Avatar
Yes jsut look around you should be able to get it out without even disconnecting other things...
I just installed my starter on my 3.4 swap with the sas and it was ridiculously easy, but i remember struggling with it when it was stock..
Old Mar 23, 2009 | 10:14 AM
okie81's Avatar
It could still be the battery; go get it load tested.
It would suck to go through all that work just to find out it was something simple, like a battery.
Old Mar 23, 2009 | 10:40 AM
gary96360's Avatar
same thing happened to me, the cable was too loose on the terminals. another time, the battery was screwed, inside lights worked but the battery didn't have enough juice left to start it.
Old Mar 23, 2009 | 11:20 AM
4Crawler's Avatar
You can often replace the solenoid contacts with the starter sitting on the frame rail:
- http://www.4crawler.com/4x4/CheapTri...rter.shtml#Fix
Old Mar 23, 2009 | 04:49 PM
its not the battery or connectors i just did a load test and it was fine and cleaned all the connectors so it looks like im pulling this biznatch out
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
