Sponsored by: CARiD
How do I change the differential fluid?
Old Mar 15, 2009 | 10:13 AM
jhershner11@mac.com's Avatar
I am not really mechanically inclined, but I like learning new things about my rig. On that note, how do I lube all the moving parts under my 95 4runner. Specifically, how do I change the fluid in the front pumkin (differential), and what fluids do I us. the previous owner did'nt take very good care of the truck, and I am trying to bring it back to life. Also, any ideas about removing rust from the undercarriage and protecting it? Not alot of rust, mostly on the nuts, bolts and pull pins and such. Any feedback would be appreciated. Thanks
Old Mar 15, 2009 | 10:15 AM
bigt's Avatar
well yes i can help you fron doff has a drain plug under neath and a fill plug on the front... i use normal gear oil..
for the rust use a wire brush on a drill or sand paper then just paint flat rust paint black i was doing it to my surf after its first winter today!
Old Mar 15, 2009 | 10:24 AM
waskillywabbit's Avatar
Make sure to remove the fill plug first, then the drain plug, so if the fill plug is messed up or stuck, you don't drain your diff and then have no way to refill.
75 w 90 gear oil
Some Rustoleum spray paint on the rust.
Old Mar 15, 2009 | 10:44 AM
how much fluid do I put in. Is there a spot to grease or lube the font axle mechanics?
Old Mar 15, 2009 | 11:02 AM
FJHammerHead's Avatar
Check out........ http://www.4x4wire.com/toyota/mainte...tenancep4.html
Old Mar 15, 2009 | 11:51 AM
gatorblue92's Avatar
75 w 90 gear oil
very good idea to remove the fill plug first... i don't even want to think about having to fill the diff through the drain plug
Old Mar 15, 2009 | 01:13 PM
Jay351's Avatar
Fill the diffs,tranny and t-case till it spills out the fill hole.
fountain
Dec 31, 2015 06:08 AM
Up&Down
Aug 11, 2015 10:04 AM
Poppie51
Aug 2, 2015 11:29 PM
Athansinis
Jul 27, 2015 08:38 AM
the1998sr5
Jul 16, 2015 06:20 AM
