Sponsored by: CARiD
Rear-end Question
Old Mar 18, 2009 | 05:47 AM
whitebyrd's Avatar
Question Rear-end Question
I am trying to find the best way to lock the stock axles (front and rear). I would like to keep it cheap and easy.
Old Mar 18, 2009 | 07:47 AM
waskillywabbit's Avatar
Welcome to Yotatech!
Cheap to $$
weld it
spool
lunchbox loxker
Detroit
ARB
This is a very basic question that could have been found easily with a search of the archives or using
Answers require some effort on your part!
I have lockers on my website but not cheap stuff. :hillbil:
Moved to "newbie tech".
Old Mar 18, 2009 | 08:05 AM
DeathCougar's Avatar
JB Weld
Chewing gum
Beef Jerky
Baling wire
Churches! Churches!!
Old Mar 18, 2009 | 08:19 AM
b/s rules's Avatar
weld the rear, some sort of locker in the front, a detroit if it's affordable. i welded both ends on mine, it works great, but steering in four wheel is a bitch. i just leave the drivers side unlocked until needed, jump out lock it and rock it. but it's going to lead to alot of other broken parts. hub studs, lockout gears, steering knuckle studs etc.etc. these are all the up grades i've had to make AFTER welding my front. never had any problems in the rear. other than doing donuts on wet pavement at 40 mph.
Old Mar 18, 2009 | 09:24 AM
whitebyrd's Avatar
Sorry for the stupidty. What I should have asked is what kind of locker do ya'll use and the pros and cons of welding the gear, because we do drive it on the road and we like to turn. and yes I know I could have used google, but I thought ya'll might have some pertty good suggestions.
Old Mar 18, 2009 | 09:30 AM
b/s rules's Avatar
ok, i'm lincoln locked, front and rear. all my buddies are welded in the rear. one is running a detroit in the front. the pavement is not a problem. wet pavement is kinda scary sometimes. that's the cheapest and easiest way to get locked
Old Mar 18, 2009 | 09:39 AM
I still vote for churches
Fwiw, i use a spool. That way, it can be uninstalled later
Old Mar 18, 2009 | 09:42 AM
scuba's Avatar
AUSSIE AUSSIE !!!
Old Mar 18, 2009 | 11:49 AM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Churches? Whats he gonna do, stuff a priest in the rear pumpkin?!!? Please tell me what your talkin 'bout. I'm lost
Old Mar 18, 2009 | 03:20 PM
Someone has clearly never seen Monty Python and Holy Grail
Old Mar 18, 2009 | 03:54 PM
DUUUHHHH! Sorry for the blonde moment!!!! As a matter of fact, it's in my computer now.....time to watch it again, it's obviously been way too long since I last saw it.
Ekki-Ekki-Ekki-Ekki-PTANG. Zoom-Boing. Z'nourrwringmm!
Old Mar 18, 2009 | 04:34 PM
okie81's Avatar
I still vote for JB weld.... no task too big!
Old Mar 18, 2009 | 05:48 PM
dropzone's Avatar
Fossilized
put a selectable upfront if this a DD that you need 4WD during the winter (yeah i know it is not cheap)
I run F/R aussies, great off road but on the road the front likes to go where it wants..
Old Mar 19, 2009 | 12:45 PM
Wardamneagle's Avatar
No one has mentioned them yet but I run front and rear TRD elockers. I control them with an FZJ80 switch and elocker ECU. It's not the cheapest or easiest solution but I wouldn't have it any other way!
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
