Sponsored by: CARiD
exhaust manifold
Old Mar 24, 2009 | 12:33 PM
bwells's Avatar
exhaust manifold
i have a 87 turbo 22rte and need to relpace the exhaust manifold. will the exhaust manifold need to be a certain kind or can it fit a 22r,re... as well?
thanks in advance
Old Mar 25, 2009 | 01:20 AM
85TurboRunner's Avatar
it uses a different manifold then a regular 22r/re.
Old Mar 25, 2009 | 02:43 AM
bowhunter1's Avatar
Original exhaust mans. for turbos can be hard to find. L C Engineering sells aftermarket ones, there not cheap. You can have yours professionally repaired. Whats wrong with yours ?
Old Mar 25, 2009 | 08:29 AM
bwells's Avatar
thanks for the info. yeah i got a crack in the manifold and trying to see what it is i can do. can i patch it or just replace it?
Old Mar 25, 2009 | 09:21 AM
DeathCougar's Avatar
Typically its not a good idea to weld on cast manifolds. For the price, you are better off just getting the LC engineering manifold or header, so it will not crack.
Old Mar 25, 2009 | 09:28 AM
4Crawler's Avatar
Yes, it is tough to weld cast iron manifolds. Over time, the heat of operation drives carbon from the exhaust into the metal. If you can find a shop that specializes in that sort of work, two options are to braze the crack or weld it with special nickel rich welding rod. Usually the manifold needs to be pre-heated prior to the repair then allowed to cool slowly to prevent cracks around the repair site.
Zach_trun
Jan 22, 2020 04:42 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
Obmi
Sep 10, 2015 03:36 AM
idadan208
Sep 7, 2015 09:06 AM
