Sponsored by: CARiD
84 head lights
Old Oct 24, 2016 | 12:03 PM
londo's Avatar
84 head lights
So I m sure some one knows the answer to this....84 SR5 No low beams, high beam indicator on, high beams work.
Switch on column, solenoid ?
Old Oct 24, 2016 | 12:48 PM
dropzone's Avatar
Fossilized
sounds like you are on the right track.
Do you have power to the low beams? Can't remember if there is a separate fuse for low and high beams.
Old Oct 24, 2016 | 01:01 PM
wyoming9's Avatar
Red face
Both Low beam elements burnt out
I have had that a few times
Remember the head lights are switched ground power is always there at the plug
Check to see if the low beam pin goes to ground like it should with the switch in low
Old Oct 24, 2016 | 01:26 PM
londo's Avatar
cant find my 12 v tester %$#@! why would the high beam indicator be on ? thinking there might be a ground fault in harness/switch
Old Oct 24, 2016 | 01:28 PM
londo's Avatar
fuses are all good, visually.
