Sponsored by: CARiD
sealer for carburetor
Old Oct 23, 2016 | 11:06 AM
azxj426's Avatar
hey all. first time post here. been looking around for an answer to my question but so far no luck so hoping someone can lead me in the right direction. 77 pickup, 20r with the water choke. did a rebuild, running great. problem is coolant leak through the gasket where carb mounts to the manifold. my plan was to use some rtv but service manual said not to, it will melt. well sure enough paper gasket alone doesn't do the job. any suggestions would be great. thanks
Old Oct 23, 2016 | 11:23 AM
wyoming9's Avatar
Red face
Been a long time but it seems something is missing
Something is warped not allowing the gasket to seal
both surfaces were cleaned so they are nice and smooth
Something in your coolant is eating right through the gasket material
Old Oct 23, 2016 | 11:48 AM
azxj426's Avatar
running water wetter in the system but never had an issue with that before. was nice and clean so possibility something warped. gives me something to check. thanks for the suggestions.
