Sponsored by: CARiD
to stating v6 3.0 1995
Old Oct 6, 2016 | 02:13 PM
cryptkeeper's Avatar
Well I took the plenum off and checked the fuel injectors and rail , there was fusl in the rails and injectors so I'm thinking no power to the tails I uhmed them out again and they are getting a little over 13 ohms , What is the voltage to the pigtail suppose to be ? I'm going to check out wiring , what is the Voltage to knock sensor , knock sensor makes its own voltage ? I'm going to see what I can do to get the Fuel injectoers to sit down farther in the Holder, do then need the little plastic cap ?Thanks for the help, I;m sit at it with this 3.0 ,
Last edited by cryptkeeper; Oct 6, 2016 at 02:17 PM. Reason: title should read ( not starting v6 3.0 1995 )
Jonny246
Aug 26, 2016 09:44 AM
Corey
41
Aug 30, 2003 07:31 AM
