Sponsored by: CARiD
3.4L cam cap arrow direction?
Old Jul 25, 2016 | 07:21 PM
mike-tracy's Avatar
Hi all, I got a 99 Tacoma v6 for cheap due to a shop installing the headgaskets backwards and telling the owner $2200 later to pound sand! Anyways, I have installed the heads correctly, now I'm on to reinstalling the cams.
The cams were not lined up correctly when I got it, so I wasn't able to put a bolt through the exhaust cams to hold its tension spring(?) in place. Also, the cam caps were all installed on the right cams (ie. all the 'E's were installed on exhaust cams, etc). But some had their arrows pointing towards the firewall, others were pointing towards the front of the car.
I'm having a hard time finding info on which way the arrows should point, and which order the cam caps go in. I come from the Subaru world, and the cam caps would be labeled "L1E, L1I" etc. The arrows on those pointed towards the front of the engine, and the number referred to which cylinder it was for. Pretty easy once you figured it out.
Thanks in advance.
Old Jul 27, 2016 | 08:08 PM
mike-tracy's Avatar
Bump! I'd like to put this back together.
diverdoyle
Jul 2, 2016 06:45 PM
DesertRatliff
Jun 30, 2016 04:34 PM
diverdoyle
Jun 29, 2016 06:58 PM
mkgarrison5
25
Mar 9, 2007 11:38 AM
Dan
Dec 31, 2006 01:11 PM
