Sponsored by: CARiD
SAS on an 89 4runner
Old May 21, 2008 | 04:51 PM
894runner1990's Avatar
hey looking to SAS my 89 4runner need some help here, so i need an axle a kit from marlin or wherever i choose and new front drive shaft. what else do i need? also whats this i hear about the offsetting of the front wheels two inches?
Old May 21, 2008 | 05:17 PM
Elvota's Avatar
Welcome to YT.
An axle kit "from marlin or wherever" will have 95% of what you need to install an SAS. As far as what else you need... that could be a very long list.
Bigger tires
New gears
Longfield Inner axles (and chromo hub gears)
Locker(s)
Armor
Etc....
Now, if you feel you don't need some of the above, your probably don't need an SAS.
A majority of the SAS kits will move the front axle forward 2" from the standard IFS placement. Reason being is that the axle will move back and up as is compresses.
Old May 21, 2008 | 05:25 PM
seafarinman's Avatar
You need to go to Pirate 4x4 and read up and learn before you try and do an SAS.
Old May 22, 2008 | 10:38 AM
thxs for the help, yes bigger tires and lockers are a definate go with this. along with new gears as well. prolly 4.88 or somethin bigger. but if i just buy the kit n get the axle then im good to go? and well the new front drive shaft but thats it?
Old May 22, 2008 | 10:47 AM
fastkevman's Avatar
Check TTORA if your state has a chapter, find them, wheel and hang out....there is bound to be someone with some first hand knowledge of doing this swap.
Plus they are usually dying to wrench on someones truck for the princely sum of pizza and beer!
Old May 22, 2008 | 10:51 AM
hahaha one problem im 17 live in nova scotia canda. so you think theyd be up here?
Old May 22, 2008 | 10:59 AM
waskillywabbit's Avatar
Welcome to Yotatech.
A SAS is but one mod among many that are needed in a progression of mods. There are tons of build up threads all over the internet concerning SAS. Search newbie!
The simple adage holds true here, that if you have to ask all these rudimentary questions about a SAS then you certainly dont need one and are not ready to tackle one.
If you WANT one, great, go for it and best of luck but do your own homework.
Old May 22, 2008 | 11:03 AM
sounds good man, no i desperatly need one for the rocks up here. just wnated to ask a few questions to make sure i dont mes it up
Old May 22, 2008 | 11:06 AM
dirtoyboy's Avatar
...I would check marlincrawler and pirate4x4. I would also recommend familiarizing yourself with the installation. I spent about a year doing research before I even picked up a tool to start. Do your homework first or it will cost you time and money.
http://www.marlincrawler.com/suspension/sas_inst.htm
http://trail-gear.com/tech/sas-instr...tructions.html
http://www.allprooffroad.com/index.p...ask=view&id=64
Old May 22, 2008 | 11:31 AM
alright man thxs for the help. i need all i can get. ive been welding since i was 12 if that helps any??? lol
Old Jun 29, 2008 | 06:29 PM
alright im back and ive done some mroe research jsut, how much wider are axles from a 1/2 ton? would it be a good diea to use a dana 44?
Old Jun 29, 2008 | 07:01 PM
NicCantDecide's Avatar
Dana 44's and the stock Toyota solid front axles are about equal in strength from what I've read. No point in spending the extra time/money to make one fit.
All Pro Offroad has Toyota/Dana60 hybrid axles, don't know too much about them but they're extravagant to say the least. Quite pricey.
I'd say stick with the toyota axle, that's what I plan on doing when I have the money and time to get it all together.
Old Jun 29, 2008 | 10:14 PM
bigarms23's Avatar
you can use a full width 44 but you will need inch wheel spacers for the back to make both axles the same width.
Old Jun 30, 2008 | 02:03 PM
lright thxe for the tips. i believe im justgonna stick with the toyota axle. one more queston. ive heard people sya i need a new front drive shaft and some say that mine will till work. any infoon that would be great thxs.
Old Jun 30, 2008 | 02:33 PM
Elvota's Avatar
New long slip front DS will be required.
To go cheap, search the term "square driveshaft"... lot's of options out there that work pretty well (generally at lower speeds)
Old Jun 30, 2008 | 09:39 PM
bigarms23's Avatar
you will need to lenghen the front driveshaft
Old Jul 3, 2008 | 10:16 PM
84socal's Avatar
going back to ur main question yes i need to space out the front to match the back ifs rear end is 1.5in wider than a toy front u can match this by getting wheel spacers or go with sky mfg. 2in hub spacer since u have ifs hubs already i would so with the sky kit
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
crashburnoveride
Aug 28, 2015 09:20 PM
karbin
Jul 5, 2015 11:37 PM
