Sponsored by: CARiD
Code 71
Old May 22, 2008 | 09:12 AM
woodendude's Avatar
Code 71
I'm coming up with a code 71 today. It's if I'm correct vsv or egr related. The vsv was replaced 2 weeks ago and the mech. checked out the egr and said that it was fine. I was having work done to pass the E test. Would bad hose line cause this code, also is it possible that the Seafoam I ran through it last night is the culprit? It came up maybe after 30 miles of driving after seafoaming and over night parked.
Derek
Old May 22, 2008 | 09:29 AM
woodendude's Avatar
it's a 95 Runner 3.0, 270,000 mi.
Old May 22, 2008 | 09:55 AM
4Crawler's Avatar
71 is telling you that the temperature sensor in the EGR is not seeing a high temperature (from the recirculated exhaust gas) in the EGR when the ECU tells it to open. So a plugged vacuum line that prevents the EGR from opeing can do it. Or soot/carbon buildup inside the EGR or on the temp. sensor can insulate the sensor from seeing the full exhaust gas temp. or reduce the gas flow so that it does not get hot enough to satisfy the ECU that the EGR valve is working.
Old May 22, 2008 | 10:27 AM
woodendude's Avatar
So for a start should I check all vacuum lines leading to and from the egr?
Old May 22, 2008 | 10:55 AM
4Crawler's Avatar
Yes, that is easy to do. Both the vacuum line as well as the little fittings they slide onto can get clogged. The Factory Service Manual has a full multi-page test procedure for the whole EGR system.
Old May 22, 2008 | 12:38 PM
woodendude's Avatar
I don't have an FSM, am I able to remove and completely clean the egr, or is there anything to delicate with it for cleaning?
Old May 22, 2008 | 12:43 PM
4Crawler's Avatar
FSMs are not hard to obtain:
- http://www.4crawler.com/4x4/FSM.shtml
and there are a few versions floating around on the net if you search for them.
EGR can be cleaned to some degree. I used a gun/pistol cleaning kit on mine, the gun cleaning solvent worked well on the carbon deposits and the small brushes allowed access to some of the internal passages.
Old May 22, 2008 | 01:17 PM
MSR's Avatar
MSR
check resistance of egr temp sensor, temp sensor only way ecm knows egr valve is opening
Old May 22, 2008 | 02:03 PM
jason191918's Avatar
http://www.ncttora.com/fsm/index.html
if only i got a dollar for every time i post this...
Old May 22, 2008 | 05:25 PM
94toy4x4fever's Avatar
What if you have a Fed truck? THat dosent have the temp sensor?
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
