Sponsored by: CARiD
Idling rough- Need a little help
Old Jun 3, 2008 | 10:07 PM
Newcomer5's Avatar
My 94 3v-ze is idling rough. I took it to the toyota dealer who recommended replacing the VAF sensor, ignition coil and igniter, ignition wiring, O2 sensor, and cleaning the throttle body and injector. This seemed a little like the carpet bomb approach to me, so I took my truck home and decided I needed to learn to fix it myself.
I used the FSM to check the VAF with an ohmmeter and the readings looked okay. I checked the ignition coil and the readings were a little off, so i just replaced the coil and igniter. It seems to be a little better, but still running rough.
SHould I try replacing the VAF anyway? I have read that the cold start injector can sometimes cause this too, but it seemed pretty involved to check it out according to the FSM. Is it pretty difficult? Any tips or other suggestions are greatly appreciated.
Old Jun 4, 2008 | 06:57 PM
82greenbeast's Avatar
describe rough, Is it sputtering? Bogging out?
Old Jun 4, 2008 | 07:08 PM
Newcomer5's Avatar
Basically when the truck is idling the engine is shaking (if you look under the hood). If I'm in the truck, idling at a stop, I can feel the truck shaking. The shaking is especially obvious if I put my hand on the gearshift. The RPMs never dip really low and sputter. Not sure what bogging out is.
Old Jun 5, 2008 | 06:27 PM
offroadie's Avatar
Hey Newcomer5 - that sounds like it may be a vacuum leak. I've had similar problems with Honda's that I've worked on - but haven't dealt with them on these trucks. I've got an '88 with a 3.0 that's having a problem that sounds like yours...
Anyone care to take a swing?
Old Jun 5, 2008 | 09:22 PM
toytech76's Avatar
Check your compression. If ya didnt know, 3.0's have a bad tendency to burn exhaust valves
Old Jun 6, 2008 | 06:56 PM
Newcomer5's Avatar
Thanks for the suggestions. I'll check the compression. I've never done it before. I checked the FSM and saw how to do it. Any tips or suggestions or things I should look out for?
Old Jun 6, 2008 | 07:05 PM
toytech76's Avatar
Your compression numbers should be 10%-15% of each other. Make sure the engine cranks equally for each cylinder and hope for the best
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
